Forum Topic - Problem accessing NV memory : (7 Items)
I a new to QNX and I am trying to port from VxWorks. In the CPU board I have NV RAM located at: 0x00F00000
I have the following code but is not working:
ThreadCtl(_NTO_TCTL_IO, 0);
int val =  munmap( 0x00F00000, 0x1F400 );
    volatile uint32_t * bat_pub_addr;
    bat_pub_addr = mmap_device_memory( 0,
					 0x1F400,
                     PROT_READ|PROT_WRITE|PROT_NOCACHE,
                     0,
                     0x00F00000);
    if (bat_pub_addr == MAP_FAILED )
      	cout << "bat pub alloc error " << errno << endl;
When I try to access the bat_pub_addr  by showing memory I get all 0xFFFFFFFF
This works OK in VxWorks, so is not a hardware issue.
Am I doing something wrong here.
Please Help.
Ricardo
AW: Problem accessing NV memory
with QNX you'll need IO privileges
add this ThreadCtl before mapping:
	int rc = ThreadCtl( _NTO_TCTL_IO, 0 );
	if(-1 == rc) {
		printf("can't get IO privileges\n");
		exit(-1);
>Von: Ricardo Ahumada [mailto:community-noreply@qnx.com]
>Gesendet: Mittwoch, 23. September 2009 00:26
>An: momentics-community
>Betreff: Problem accessing NV memory
>Hi,
>CPU board I have NV RAM located at: 0x00F00000 I have the
>					 0x1F400,
>                     0,
>                     0x00F00000);
>all 0xFFFFFFFF This works OK in VxWorks, so is not a hardware issue.
>Please Help.
>Ricardo
>QNX Momentics Community Support
>http://community.qnx.com/sf/go/post38519
Re: AW: Problem accessing NV memory
I tried checking the value in
		if(-1 == rc) {
			exit(-1);
and is 0 (no error) so privileges do not seem to be the problem.
Ricardo
AW: AW: Problem accessing NV memory
as you get the MAP_FAILED from mmap()
have you checked errno?
hp
>Gesendet: Mittwoch, 23. September 2009 16:04
>Betreff: Re: AW: Problem accessing NV memory
>		if(-1 == rc) {
>			exit(-1);
>Ricardo
>http://community.qnx.com/sf/go/post38554
Re: AW: AW: Problem accessing NV memory
I do not get a MAP_FAILED
Re: Problem accessing NV memory
The munmap is not necessary - the first parameter to munmap is a virtual address, not a physical address!
I'm not sure that's the error though.  What platform is this running on?
Ricardo Ahumada wrote:
> 					 0x1F400,
>                      0,
>                      0x00F00000);
> Please Help.
> Ricardo
cburgess@qnx.com
This is running in a Centrino 1 GHz processor
