Forum Topic - OS corruption: (4 Items)
OS corruption
I have a QNX 4 file system in CF in a partition. While working with it, if abruptly power is removed, is there a chance
for OS to get corrupted and thus the system is prevented from booting?
Re: OS corruption
> abruptly power is removed, is there a chance for OS to get corrupted and thus
I wouldn't exclude this possibility.
Jeevan
RE: OS corruption
Is there a way by which this can be avoided so that I can use CF with QNX4 file sytem and can turn the power off
abruptly even every single time??
Sent: Monday, June 29, 2009 8:20 PM
To: momentics-community
Subject: Re: OS corruption
Jeevan
http://community.qnx.com/sf/go/post32731
DISCLAIMER:
The contents of this e-mail and any attachment(s) are confidential and intended for the named recipient(s) only.
It shall not attach any liability on the originator or HCL or its affiliates. Any views or opinions presented in
this email are solely those of the author and may not necessarily reflect the opinions of HCL or its affiliates.
Any form of reproduction, dissemination, copying, disclosure, modification, distribution and / or publication of
this message without the prior written consent of the author of this e-mail is strictly prohibited. If you have
received this email in error please delete it and notify the sender immediately. Before opening any mail and
attachments please check them for viruses and defect.
Re: RE: OS corruption
> file sytem and can turn the power off abruptly even every single time??
If a write is occurring and the power is removed, corruption can happen.
There are some things that can be done to minimize the problem like:
mount filesytem read-only if/when possible (stops access time update)
open the files synch or use the "blk commit=high" option
umount the filesystem before the power is removed
decrease delayed write time with the "blk delwri" option
create a separate partition for writable files
do not put put writable files in the root directory
pre-grow files after creation
balance directory tree. ie limit directory levels and number of files
One other thing to note is that if power is removed during a write,
subsequent reads will fail until it is written.
Hope this helps.
Jeevan
For more info please post to the experts in the filesystem forum.
