Forum Topic - Tracelogger info during system boot up: (11 Items)
I want to get trace logger info. during system boot up.
On one of the forum i seen below command which i included in the build script but it is not working. trace logger itself
 not yet started.
tracelogger -s15 &
Please suggest whats happening here also let me know any utility is there to work out which i can include on my build
script so during boot up the trace logger will be automaticallly started and kev file will be available.
Thanks & Regards,
Robin
Re: Tracelogger info during system boot up
Have a look at the script portion of a build file that I have attached here.  You will see how to start the tracelog and
 how to finish it.  The done_trace called at the end of the script simply injects a user event into the kernel log, it
is not required for what you are doing.
After the system has booted, copy the resulting kev file from /dev/shmem
- Dave Nickerson
>  not yet started.
> tracelogger -s15 &
> Thanks & Regards,
> Robin
Attachment: Text trace_boot.bsh 1.17 KB
I have a requirement like I have to start the tracelogger when one event is passed and stop the logger when i received
the response for that event. I want to embedd run it in the code.
Please help me know what is the command to use the same
Robin
AW: Tracelogger info during system boot up
you have to start tracelogger in demon modem,
check the ref manual for this
http://www.qnx.com/developers/docs/6.4.1/neutrino/utilities/t/tracelogger.html
then you have to use TraceEvent() calls to do what you want to
here's an example:
// start tracing
// and configure filters
TraceEvent(_NTO_TRACE_ADDALLCLASSES);
TraceEvent(_NTO_TRACE_SETALLCLASSESFAST);
TraceEvent(_NTO_TRACE_SETEVENTWIDE,_NTO_TRACE_THRUNNING);
TraceEvent(_NTO_TRACE_START);
// stop it
TraceEvent(_NTO_TRACE_STOP);
TraceEvent(_NTO_TRACE_FLUSHBUFFER);
check the manual
http://www.qnx.com/developers/docs/6.4.1/neutrino/lib_ref/t/traceevent.html
HTH
/hp
>Von: Robin wood [mailto:community-noreply@qnx.com]
>Gesendet: Mittwoch, 2. Dezember 2009 15:48
>An: momentics-community
>Betreff: Re: Tracelogger info during system boot up
>Hi,
>one event is passed and stop the logger when i received the
>Thanks,
>Robin
>QNX Momentics Community Support
>http://community.qnx.com/sf/go/post43013
Re: AW: Tracelogger info during system boot up
BTW - if you want ALL events enabled by default, you can use the -E option...
> here's an example:
> // start tracing
> // stop it
> check the manual
> HTH
> /hp
>> Hi,
>> Thanks,
>> Robin
> http://community.qnx.com/sf/go/post43015
cburgess@qnx.com
As you suggested i gave (tracelogger -d1 -E -w -c -S32M -M -v &) but it is not working. Below is the error message i got
_____________________________________________________________
Process 4 (mount) exited status=0.
tracelogger: illegal option -- E
Process 16389 (tracelogger) terminated SIG code=0 by process 0 value=0.
______________________________________________________________
Please help on this.
Robin
Ah -E was added in 640 - so you will have to do the event setup that HP noted.
Cheers,
Colin
Robin wood wrote:
> As you suggested i gave (tracelogger -d1 -E -w -c -S32M -M -v &) but it is not working. Below is the error message i got.
> Thanks,
> Robin
> http://community.qnx.com/sf/go/post43021
cburgess@qnx.com
This is working if i give (tracelogger -d1 E -w -c -S32M -M -v &) without any "-"
Robin
i used the below cmd but i getting the error in running the Trace looger
Cmd:
Error:
Unable to start "tracelogger" (2)
I want to get the serious of KEV files one after the other in the same cycle for different scenario. After getting first
 KEV file i downloaded the file and then tried to delete by using "rm -f *.kev". But if again i try to start the
tracelogger it is not working. There is no KEV files generated in \dev\shmem area.
Please let me know how to delete one file and to start the other in the same cycle. I am starting and stopping the
tracelogger in the code itself by using the below cmd.
//start the trace
//stop the trace
as you're using daemon mode,
you will have to tell tracelogger to end before you're copying the file.
a TraceEvent(_NTO_TRACE_STOP) only tells proc to stop tracing, but not tracelogger to record.
so after doning the
you'll have to
   slay tracelogger
or
   SignalKill(0, LoggerPid, 0, SIGTERM, SI_USER, 0);
as long as tracelogger hasn't finished because the given data limit (-S16M) is reached.
now you can copy the file.
You will have to restart tracelogger for further logging sessions,
but you don't have to delete the *.kev files - they will be overwritten by subsequent restarts of tracelogger
HTH
/hp
