Forum Topic - access to floating licence via VPN:
I have a question about which protocol or which port the QDE Momentics Version: 7.0.4.v202004031918 (qnx 6.5 and 6.6
SDKs) are communicate with the licence-server, cause I've got some trouble with my VPN connection in homeoffice.
Connected to our company network over vpn:
I can start the QDE but as soon as I want to build a project I see in the console output that the qcc is called
accordingly but nothing else happens.
When I call the qcc via the console with verbose output the behavior is the same, no output occurs.
In the corporate network itself:
After starting the build process, the compiler is called accordingly and the message :
Checkout succeeded: *****/*************
	License file: *****@servername.de.company.net
	License Server:  *****@servername.de.company.net
The corresponding license server is reachable via both connection paths and the connection paths are displayed correctly
 via tracert, my assumption is that a corresponding port is not released.
Or is that an https connection and i will need a specific cert. ?
Kind regards
