Forum Topic - Third party library support on QNX - cross compilation of dependent library:
Would like to know how to compile/install third party library like Point cloud
library and its dependant c++ libraries like boost,eigen3,flann etc.
1. Do we have to build/compile each dependant library using qcc compiler
2. Does qnx provide prebuilt shared libraries for boost,eigen3,flann etc which
we we can directly use and link with our application
3. Or Dependant posix complaint libraries build on linux_x86 can be used to
link with an application intended to run on qnx platform
Madhav
Re: Third party library support on QNX - cross compilation of dependent library
Hi Madhav,
1. yes, unless it is provided by other parties (like QNX themselves or others). Knowing the POSIX compliance of QNX,
this is often a task that can be done with very moderate effort and has the advantage that you can select exactly the
source version you want and do the "configure" part yourself.
2. somtimes, in the QNX Software Center is a section on "Ported Third-Party Software"
3. No, binaries built for Linux do not run on QNX (at least not on 6.x where we actually ran into this issue - maybe
possible on 7.x but I really doubt it. Maybe QNX guys can clarify that).
Albrecht
