Forum Topic - Unable to create QNX RTOS with VM installation DVD using latest VMware Player:
Hi I am trying to install QNX RTOS with VM installation DVD which I downloaded from "http://www.qnx.com/download/feature
.html?programid=26217" using latest VMware Player 7. Please help me. I want to develop apps for QNX. But I am unable to
create a target using VMware on Windows 7. Any clues greatly appreciated. Thanks.
Re: Unable to create QNX RTOS with VM installation DVD using latest VMware Player
Can I install QNX SDP and QNX RTOS on the same machine?
Hello Shiva,
QNX SDP is the QNX Software Development Platform. The QNX Neutrino
Realtime Operating System is the OS.
Perhaps you could start by reviewing some of the documentation at:
http://www.qnx.com/developers/docs/660/index.jsp
Look under QNX Software Development Platform, where you'll find OS Core
Components > System Architecture. This should give you some useful
information about how things fit together, and how you can get started.
Good luck,
Nicola Vulpe
>QNX Momentics Community Support
>http://community.qnx.com/sf/go/post113029
>momentics-community-unsubscribe@community.qnx.com
Hi Nicola,
yeah I have seen those documents. Here is what I am trying to do.
I am planning to do QNX app development for car infotainment systems who are QNX enabled.
From my basic research, I have to install QNX Software Development Program and QNX SDK for Apps and Media. and I have
successfully done till this. I can also launch QNX Momentics IDE 5.0 and write code.
Next part is to create a QNX target. I hope there are two ways to do that.
1. Buy QNX board or device and connect to PC and start working as provided steps.
2. Create VMware and install QNX RTOS on that slice, which will work as Target for deployment. (just like emulator).
I want to create target as mentioned in the 2nd step. I tried to follow the steps mentioned in section "3. Installing
the QNX Neutrino RTOS on the target system" @ http://www.qnx.com/developers/docs/6.4.1/momentics/quickstart/about.html.
But when I do that I get following error. Please find the attachment.
Or please suggest me if there is any other way of setting up a QNX Target for installing apps.
Attachment: Image QNX error.png 81.6 KB
Hi Shiva,
Have you tried going to the Apps and Media 1.1 on Foundry 27? Look for the
document "Working with Target Images". Chapter one provides step-by-step
instructions for copying a reference image onto a target, including for
VMWare.
Have fun.
N
On 2015-01-22 16:45 , "shiva aetherpal" <community-noreply@qnx.com> wrote:
>Hi Nicola,
>are QNX enabled.
>Program and QNX SDK for Apps and Media. and I have successfully done till
>provided steps.
>the steps mentioned in section "3. Installing the QNX Neutrino RTOS on
>Thanks
>http://community.qnx.com/sf/go/post113041
Hi Nicola,
I can not find any thing with related to "Working with Target Images" on Foundry27. I am on evaluation 30-day trial
version, is that the reason I am not able access all the documents or I can not configure a Target?
Thx
Hi Nicola,
 Foundry27. I am on evaluation 30-day trial version, is that the reason I am
This is the only link I found to install a Target for development. http://www.qnx.com/developers/articles/inst_5856_3.
html
 Thx
Now I am able to create a Target successfully. I do not know what is the issue, all the time I was following the correct
 procedure, but some thing was going wrong. After several trials I could install it properly and run my test
applications.
Thanks for your replies Nicola, they was helpful.
Hi Shiva,
Glad to hear you got your system going. You are most welcome. Have fun!
N
>issue, all the time I was following the correct procedure, but some thing
>my test applications.
>http://community.qnx.com/sf/go/post113073
