Forum Topic - Setting up a TFTP Server & Terminal: (1 Item)
Hi guys,
I try to upload QNX on a STKa28 board from TQ. Therefor I wanted to use the TFTP Server from the System Builder view in
the Momentics IDE and connect with the Terminal.
After I changed the Terminal Settings (I tried SSH and Telnet) the Terminal can't connect to the board (with the error "
Network is unreachable: connect").
The board itself is set up according to the instructions from the producer so I assume the error is somewhere in the
Terminal settings.
I hope you can help and if you need some more informations don't hesitate to ask me, I will try and answer them as fast
as I can.
Yours sincerely
Adrian
