Forum Topic - precise timing on qnx: (4 Items)
I'm trying to write software that will respond in a very precise matter to ISR (need it to be much better than 1ms), and
 i'm wondering what is the best practice for that.
reading "Tick, Tock: Understanding the Neutrino Microkernel's Concept of Time" + "Clocks, Timers, and Getting a Kick
Every So Often" i got the feeling i can't get better than the system tick .
 1) am i right? do you know any way to get better than system tick?
 2) does someone has experience with changing the tick lower than 1ms and can tell me how much it affected the system
(i'm running on beaglebone)?
thanks
RE: precise timing on qnx
If you want to react to an ISR you shouldn't need anything related to timer precision. When the ISR is is trigger just
get it to generated an event of some sort and get your program to react to it.  You can also get a thread to wait on a
ISR.
> -----Message d'origine-----
> De : Yogev Vaknin [mailto:community-noreply@qnx.com]
> Envoyé : 26 octobre 2013 09:26
> À : momentics-community
> Objet : precise timing on qnx
> (need it to be much better than 1ms), and i'm wondering what is the best
> practice for that.
> + "Clocks, Timers, and Getting a Kick Every So Often" i got the feeling i can't get
> tell me how much it affected the system (i'm running on beaglebone)?
> thanks
> http://community.qnx.com/sf/go/post106290
> To cancel your subscription to this discussion, please e-mail momentics-
> community-unsubscribe@community.qnx.com
Re: RE: precise timing on qnx
I'm not sure I was clear enough.
lets say I get an ISR(some external hardware input), and i want to react to it with some external output  after *exactly
* one second.
If 1ms precision was fine for me, it seems that i could just use QNX timers as described in "Clocks, Timers, and Getting
 a Kick Every So Often".
 But my question was what should I do if I need better than 1ms precision (more like 1us, and below).
> precision. When the ISR is is trigger just get it to generated an event of
> wait on a ISR.
> > Hi,
> ISR
> > practice for that.
> Time"
> can't get
> can
> > thanks
RE: RE: precise timing on qnx
> Envoyé : 28 octobre 2013 10:33
> Objet : Re: RE: precise timing on qnx
> some external output  after *exactly* one second.
> described in "Clocks, Timers, and Getting a Kick Every So Often".
1us , assuming 1G and and average instruction of 2 cycles , that means  500 instructions between timer interrupt...  Not
 good
So to solve your problem you need another source of interrupt that you program to get the event when required.  I`m not
familiar with the beagleboard, it might have an extra timer that the kernel isn`t using.  But getting in the range, 1us
and below, you will have to take into account hardware and kernel latency for the incoming ISR and same thing for the
triggering of the output!
Maybe the beagleboard has some timer hardware that can automatically start on an incoming pulse and trigger an output
after a count as expired, this is typical of timers.
> > timer precision. When the ISR is is trigger just get it to generated
> > also get a thread to wait on a ISR.
> > > Hi,
> > > matter to
> > ISR
> > > Concept of
> > Time"
> > > + feeling i
> > can't get
> > > 1ms and
> > can
> > > thanks
> > > momentics- community-unsubscribe@community.qnx.com
> http://community.qnx.com/sf/go/post106315
