Forum Topic - Unreferenced Assembly commands with function profiling using gcc 4.6.1 toolchain: (6 Items)
Greetings all,
due to some C++11 things we need we switched to the gcc 4.6.1 toolchain for qnx&momentics more than a year ago. We also
have some functions using assembly language as well as compiler intrinsics. However, when using profiling with function
instrumentation, we get tons of unresolved references, basically for every single assembly or intrinsic command.
I counterchecked with support here, and the old 4.4.2 toolchain works fine, but is not an option for us due to missing C
++11 support and some bugs.
Has anybody else had this  experience or does anybody know whether a newer toolchain such as 4.7.1 resolves the problem?
 We do not want to switch as changing the toolchain includes several changes to the qnx target as well (such as changing
 symbolic ;links for several libs), none of them really documented on the toolchain page, which is a sorrow.
I am looking forward to getting help,
kindest thanks,
Andy
Re: Unreferenced Assembly commands with function profiling using gcc 4.6.1 toolchain
Hi again,
still hoping for help, find attached a protec demonstrating the exact problems.
Preliminaries: The project was created with IDE 5.0 and toolchain gcc 4.6.1. Both are officially available and
downloadable fromt this website. Note, however, that, when importing the poject file into IDE version 4.8 or before, the
 build variances need to be reset to x86.
Our development environment runs on WIN 7 64 bit, the toolchain 4.6.1 or better is necessary due to C++11 suuport we
need, hence using 4.4.2 is not an option for us.
Looking forward for getting information and help,
kindest regards,
Andreas
Attachment: Compressed file intrinsicsMomenticsProfileDemo.zip 31.69 KB
I forgot the compiler settings: -Wc,-std=gnu++0x -mfpmath=sse -msse4.1 -mstackrealign -march=corei7
We get the undefined references when compiling for profiling with function instrumentation.
Thanks again,
Andreas
You could compile with -finstrument-functions-exclude-function-list=_mm_
to exclude the intrinsics from function instrumentation.
Ryan Mansfield
Greetings,
the compiler settings work around to exclude the intrinsics from function instrumentation seems to work fine so far.
Thanks for the advice!
Andy
RE: Unreferenced Assembly commands with function profiling using gcc 4.6.1 toolchain
> -----Message d'origine-----
> De : Andreas Beschorner [mailto:community-noreply@qnx.com]
> Envoyé : 3 juillet 2013 02:13
> À : momentics-community
> Objet : Re: Unreferenced Assembly commands with function profiling using
> gcc 4.6.1 toolchain
> Hi again,
> problems.
> Both are officially available and downloadable fromt this website.
Just a small correction, first 4.6.1 is not officially available, it`s in experimental/prototype state.  While you are
at it you might give a try to 4.8.1. It has better C++11 support.
> the build variances need to be reset to x86.
> better is necessary due to C++11 suuport we need, hence using 4.4.2 is not
> an option for us.
> kindest regards,
> Andreas
> http://community.qnx.com/sf/go/post102876
> To cancel your subscription to this discussion, please e-mail momentics-
> community-unsubscribe@community.qnx.com
