RE: Including a C++ class in a Photon Appbuilder Project
03/26/2008 2:03 PM
post6161
Hi Gabriel,
There are a couple of gotchas when working with C++ and Phab, and they're
listed below:
PhAB fails to link C++ code
Q: I have C++ code being called in a callback, and PhAB won't link it. Why?
A: Is it in a file with a .cpp extension? Our default make settings only
recognize .cc extensions at this time. You can fix this by adding this line
near the top of your common.mk file:
EXTRA_SUFFIXES+=cxx cpp
PhAB fails to compile C++ code
Q: proto.h does not like my C++ function declarations. How can I fix this?
A: You can use the option that disables approto.
http://www.qnx.com/developers/docs/6.3.0SP3/photon/prog_guide/generating.htm
l#Prototypes
Specifically you'll need to do the following:
To suppress the generation of prototypes in proto.h:
1. Press F2 or from the Project menu, choose Properties to open the
Project Properties dialog.
2. Click the Generate Options tab.
3. Disable the Scan Source Files for Prototypes option.
Cheers,
-Brian
> From: Gabriel Aguirre-Ollinger [mailto:gaguirre@northwestern.edu]
> Sent: Wednesday, March 26, 2008 13 45
> To: momentics-community
> Subject: Including a C++ class in a Photon Appbuilder Project
> Hello,
> I'm developing a Photon Appbuilder project in QNX Momentics
> v6.3. So far I've written all the code in C, but now I'd
> like to include a C++ class for matrix operations. However,
> it doesn't seem to be a simple matter of adding the C++ file
> to the project. At this point the compiler cannot find the
> standard C++ libraries or recognize the C++ syntax in the
> source file. Can anybody tell me what's the correct way to do it?
> Thanks!
> http://community.qnx.com/sf/go/post6160
