Forum Topic - Update tool chain in QNX6.5.0: (9 Items)
Is there a possibility to keep the same environment but update only the gcc compiler that comes with the tool chain? I
am using 4.4.2, and would like to update it to 4.6.
-Zahira
Re: Update tool chain in QNX6.5.0
On 12-04-03 02:07 PM, Zahira Ammarguellat wrote:
> Hello,
Yes. Download the appropriate gcc package for your host, and extract it
into your root QNX directory (e.g. /opt/qnx650, C:/QNX650, etc).
Ryan Mansfield
RE: Update tool chain in QNX6.5.0
> -----Message d'origine-----
> De : Ryan Mansfield [mailto:community-noreply@qnx.com]
> Envoyé : 3 avril 2012 14:33
> À : momentics-community
> Objet : Re: Update tool chain in QNX6.5.0
> > Hello,
> compiler that comes with the tool chain? I am using 4.4.2, and would like to
> update it to 4.6.
Just to make sure.  I`m assuming this still not an official release?
> Yes. Download the appropriate gcc package for your host, and extract it into
> Regards,
> Ryan Mansfield
> http://community.qnx.com/sf/go/post92425
>>> Hello,
>> update it to 4.6.
It's as official as an foundry release is ever going to get. :)
Ryan Mansfield
Ryan,
What is the right gcc package?
In the Core Development Tools under File Releases > GCC > GCC4.6 there are several packages.
I am looking for a Linux version. I am assuming that what I need is linux-gcc-4.6.2.tar.gz. When I extracted this
package I don't seem to get all the include files. For example <string.h> doesn't seem to be there? I am in the right
place?
Also what are the nto-gcc... packages?
-Zahira
Yes those are the right packages. If you are using a linux host then download the linux-gcc-4.6.2.tar.gz. string.h isn't
 part of gcc. It is part of libc that's part of 6.5.0
The nto-gcc-4.6.2.tar.gz packages are for self hosted x86 machines.
Ryan Mansfield
Ryan,
I am therefore missing something.
To get to use the new tool chain, I wanted to replace my "target" directory under /opt/qnx650 by the new target in the
linux package mentioned below, and do the same with the host directory. That wouldn't work because these new target and
host directories don't seem to contain everything?
-Zahira
>-----Original Message-----
>From: Ryan Mansfield [mailto:community-noreply@qnx.com]
>Sent: Tuesday, April 03, 2012 5:28 PM
>To: momentics-community
>Subject: Re: Update tool chain in QNX6.5.0
>the linux-gcc-4.6.2.tar.gz. string.h isn't part of gcc. It is part of libc that's part of
>6.5.0
>Regards,
>Ryan Mansfield
>http://community.qnx.com/sf/go/post92430
On 12-04-04 10:16 AM, Zahira Ammarguellat wrote:
> Ryan,
> Thanks,
It's not a replacement to your "target" directory, you extract it over
top of the existing 6.5.0. You're confusing the toolchain with the OS.
Ryan Mansfield
Ok. Got it. Thanks.
Now I am less confused :-)
>Sent: Wednesday, April 04, 2012 10:25 AM
>> Ryan,
>under /opt/qnx650 by the new target in the linux package mentioned below,
>new target and host directories don't seem to contain everything?
>> Thanks,
>Regards,
>Ryan Mansfield
>http://community.qnx.com/sf/go/post92451
