Forum Topic - Server Termination detection from within the Client Process: (2 Items)
I have a Client Server model sending and receiving both custom messages and pulses, on the server side I am using
name_attach and MsgReceive / MsgReceivePulse, on the client side I am using name_open and MsgSend / MsgSendPulse.
I am attempting to determine if the server has terminated, I plan to use critail process monitoring to restart the
server should it be terminated.
I would is possible rather not call name_open, MsgSendPulse, name_close every time I have message.
On the client side I was hoping to do something like this:
name_open()
for(;;)
    status = MsgSendPulse_r()
    if(status !=EOK)
         if(status == EBADF)
              name_open()
However MsgSendPulse_r always returns EOK, even when the server has been terminated and the entry in the namespace /dev/
name/local has been removed.
Any ideas how I can achieve this.
Regards
William
Re: Server Termination detection from within the Client Process
> pulses, on the server side I am using name_attach and MsgReceive /
> MsgSendPulse.
_NTO_CHF_COID_DISCONNECT in ChannelCreate() on Your client's side.
requests that the kernel deliver the client a pulse when _a_ server goes away. It is possible for a client to have a
channel ,a subsequent message-receive loop with a receive buf  what can hold a pulse the pulse will have
_PULSE_CODE_COIDDEATH as code.
Hope this helps.
Jeevan
