Forum Topic - Bindres error on Windows 7: (4 Items)
I am trying to run bindres under momentics in Windows 7 and getting the following error:
    BINDRES iFS/debug/AMO/bin/laser
rm: Skipping iFS/debug/AMO/bin/laser.tmp -- no write permission
bindres: command 'rm iFS/debug/AMO/bin/laser.tmp' failed
make: *** [iFS/debug/AMO/bin/laser] Error 1
make: *** Deleting file `iFS/debug/AMO/bin/laser'
I have tried changing write perms on the file, changing executables to have admin privileges, change the ACU settings;
all to no avail.  Ideas?
Re: Bindres error on Windows 7
change permission on the dir not on file
> http://community.qnx.com/sf/go/post87991
Thanks, Elena, but I tried that too and it did not work.
RE: Bindres error on Windows 7
This sounds a lot like PR49311, which was supposed to be fixed as of
6.4.0. Which version of Momentics are you running? That PR was verified
against Windows Vista, but there could be other issues in Windows 7.
When you say you changed the "ACU settings" does that mean you disabled
User Account Control (UAC)? If not then try disabling it as a
workaround.
It could still be a permission issue, eg. filesystem vs. user
permissions. Without access to your machine I can't do much... but you
can check if the problem happens as an administrator user vs. regular
user, or in a different directory, etc.
Max
From: Terry Laughlin [mailto:community-noreply@qnx.com]
Sent: Wednesday, August 10, 2011 3:50 PM
To: momentics-community
Subject: Bindres error on Windows 7
following error:
have admin privileges, change the ACU settings; all to no avail.  Ideas?
