Re: QNX Code Coverage - HTTP ERROR 500
10/05/2010 5:13 PM
post69671
Can you send your workspace log file? It's under
<workspace>/.metadata/.log
Reply-to: post69539@community.qnx.com
To: momentics-community <post69539@community.qnx.com>
Subject: QNX Code Coverage - HTTP ERROR 500
Date: Tue, 5 Oct 2010 06:37:55 -0400 (EDT)
I am able to import all the code coverage files from my target and when I try to generate a code coverage report on my
QNX IDE (Version: 4.7.0), I get this error:
HTTP ERROR 500
Problem accessing /qnx-coverage/coverage. Reason:
Exception occurred during ctor/Transformation:
debug is false
Parsing XSL Stylesheet Document from configuration: /webapp/WEB-INF/xslt/cov-html.xslt
Performing transformation...
javax.xml.transform.TransformerException: java.lang.NullPointerException
Any help on this would be appreciated.
Regards
Sunil Keshava
06/18/2018 2:48 AM
post118879
> to generate a code coverage report on my QNX IDE (Version: 4.7.0), I get this
> error:
> HTTP ERROR 500
> debug is false
> html.xslt
> Regards
> Sunil Keshava
The first thing you need to know about an "Internal Server Error" is that the error can only be resolved by fixes to the
Web server software. It is not a client-side problem meaning that the problem is not with your browser, your computer,
or your internet connection. However, there are often ways to quickly get around the problem:
Check the Error Logs
Errors in .htaccess files
Clear your browser cookies and cache
Reload or Refresh the Webpage
Not Yet?
If you've tried to troubleshoot your 500 server error and still can't fix it, then you may need to speak to your web
host and see if they are able to find what process or script is causing the error.
http://net-informations.com/q/mis/500.html
