Forum Topic - setevn and clearenv - how efficient are they?: (2 Items)
I have a QNX 6.4.1 system with a two-stack io-pkt network manager. In one of my applications, there is a need to
communicate packets between both stacks. I wanted to know what would be the best and most efficient way to switch
between stacks.
Currently, I do have a solution - I use the setevn() and clearenv() calls to set and reset the "SOCK" environmental
variable so that I am looking at the correct stack. However, this means that every time there is a packet to be
transmitted, I have to use the setenv() and clearenv() calls to make sure that I am transmitting to the right stack. I
am worried if these setenv() and clearenv() take too much time or resources to do what they do.
Any info would be appreciated
Regards
Sunil
Re: setevn and clearenv - how efficient are they?
On Mon, May 03, 2010 at 06:11:57AM -0400, Sunil Keshava wrote:
between stacks.
Check out these two threads for ideas on targeting specific stacks
without the env twiddling.
http://community.qnx.com/sf/discussion/do/listPosts/projects.core_os/discussion.newcode.topc4724
http://community.qnx.com/sf/discussion/do/listPosts/projects.networking/discussion.general.topc5424
