Forum Topic - System builder problem: (21 Items)
Hello all
I have QNX® Momentics® Integrated Development Environment
Version: 4.5.0
Build id: I20081019
I try to create bootable image.
I create bootable partition (type 179) with fdisk. Write to it loader. All ok.
Then I create System Builder project (Name qnxbase)and try to create qnxbase.ifs file. All ok, until size of IFS file <
3M.
Then I googled this probelm, and find this solution.
Solution:
I add to my system builder project Efs image. Add binary (for example - pidin) to efs image. I build efs image - as
result - qnxbase-flash-1.efs.
Then I build my qnxbase project  -as result  -   efs-qnxbase.bin. Then i download this image to my target. When I boot
all - ok, but I don't find binary, that i add to efs image. I don't find  pidin.
What I do wrong? Please help?
Re: System builder problem
Hi, Oleg,
The EFS image won't be useful until it is mounted.  This is commonly
done in the IFS boot script.  See the mount reference documentation for
details:
http://www.qnx.com/developers/docs/6.4.0/neutrino/utilities/m/mount.html
HTH,
Christian
On 27/02/10 02:54 AM, Oleg Gopov wrote:
> Hello all
> Version: 4.5.0
> Build id: I20081019
> Then I create System Builder project (Name qnxbase)and try to create qnxbase.ifs file. All ok, until size of IFS file<
  3M.
> Solution:
> http://community.qnx.com/sf/go/post48467
Hello, Christian .
I don't find usefull information in mount reference.
I don't understand how to extract efs file from my COMBINED image file  -
efs-qnxbase.bin   , when my system booted. I find in forums, that I must invoke  DEVF-RAM driver. This is driver for
flash filesystem.
It create /dev/fs0 and /dev/fs0p0 files. But mount command with this special devices is failed. I read in "Building
Embedded systems" document , that I must cat to this files image file . For example, cat xxx.efs > /dev/fs0p0.  Then if
I reboot DEVF-RAM driver,  System create /fs0p1 directory , where  belonged files from EFS - image.
I have very interest question.
How to extract efs - image from my COMBINED image file, that I create in System Builder Perspective
Hi, Oleg,
If you are combining your IFS and EFS images using the mkimage tool
(which the IDE's System Builder uses to combine images) then it is my
understanding that procnto should find all of the embedded files and
make them available in the run-time filesystem.  Other procedures for
mounting EFSes should only be necessary if the images aren't combined,
for example, if an EFS is included as a regular file in the IFS.
Do you see any warning messages in the System Builder's build console
when you build and combine your images?  Do you get different results if
you use the command-line tools, yourself, instead of System Builder?
Originally, you indicated that the image stopped working correctly when
its size exceeded 3MB.  If you are combining images, would you not still
have that problem?  It seems that the work-around would require
downloading and mounting the EFS separately from the boot image ...
Cheers,
Christian
On 02/03/10 08:00 AM, Oleg Gopov wrote:
> Hello, Christian .
flash filesystem.
Embedded systems" document , that I must cat to this files image file . For example, cat xxx.efs>  /dev/fs0p0.  Then if
> http://community.qnx.com/sf/go/post48604
> Hi, Oleg,
> Cheers,
Hi Cheers.
This is output. I find no warnings.
Building Image: qnxbase
C:\QNX640\host\win32\x86\usr\bin\mkifs.exe -vvv C:/Docs/workspace/.metadata/.plugins/com.qnx.tools.ide.builder.core/.
projects/new-vp9/qnxbase.mkxfs C:/Docs/workspace/new-vp9/Images/qnxbase.ifs
  Offset   Size    Entry   Ramoff Target=Host
  400000    3f8        0      --- C:/QNX640/target/qnx6/x86/boot/sys/bios.boot
Execute: ldrel -s!* -p -l -t 0x4004f8 "C:/QNX640/target/qnx6/x86/boot/sys/startup-bios-32" "C:\DOCUME~1\05AC~1\LOCALS~1\
Temp\QE7000a50fee.tmp"
Execute: qcc -bootstrap -nostdlib -Wl,--no-keep-memory -Vgcc_ntox86 -Wl,-Ttext -Wl,0xf0016000 -o"C:\DOCUME~1\05AC~1\
LOCALS~1\Temp\QE7000a510c9.tmp" "C:/QNX640/target/qnx6/x86/boot/sys/procnto"
  4003f8    100     ----      --- Startup-header
  4004f8  137d8   404038      --- C:\DOCUME~1\05AC~1\LOCALS~1\Temp\QE7000a50fee.tmp (480015334)
  4138d8     5c     ----      --- Image-header
  413934    be8     ----      --- Image-directory
    ----    ---     ----      --- fs
  41451c    608     ----      --- proc/boot/.script=C:\DOCUME~1\05AC~1\LOCALS~1\Temp\QE7000a50fad.tmp
  414b24     18     ----      --- etc/fstab=C:\QNX640\target\qnx6\etc\fstab (191537521)
  414b3c     12     ----      --- proc/boot/unlink_list=C:\DOCUME~1\05AC~1\LOCALS~1\Temp\QE7000a50fbe.tmp (449623294)
  414b4e      7     ----      --- .diskroot=C:\QNX640\target\qnx6\etc\.diskroot (2932538503)
  415000  6b000 f0047ef0      --- proc/boot/procnto=C:\DOCUME~1\05AC~1\LOCALS~1\Temp\QE7000a510c9.tmp (2071201803)
  480000  75000    3d05a      --- proc/boot/libc.so.3=C:\QNX640\target\qnx6\x86\lib\libc.so (76736551)
    ----    ---     ----      --- proc/boot/libc.so=libc.so.3 (76736551)
  4f5000   6cae     17f0      --- proc/boot/libhiddi.so.1=C:\QNX640\target\qnx6\x86\lib\libhiddi.so (2601117683)
    ----    ---     ----      --- proc/boot/libhiddi.so=libhiddi.so.1 (2601117683)
  4fc000   b060     3120      --- proc/boot/libusbdi.so.2=C:\QNX640\target\qnx6\x86\lib\libusbdi.so (2085745603)
  507060    bcd     ----      --- etc/system/sysinit=C:/QNX640/target/qnx6/etc/system/sysinit (3480538215)
    ----    ---     ----      --- proc/boot/libusbdi.so=libusbdi.so.2 (2085745603)
  508000  104d0     3550      --- proc/boot/libcam.so.2=C:\QNX640\target\qnx6\x86\lib\libcam.so (4090673103)
    ----    ---     ----      --- proc/boot/libcam.so=libcam.so.2 (4090673103)
  519000  2462a     4d20      --- proc/boot/io-blk.so=C:\QNX640\target\qnx6\x86\lib\dll\io-blk.so (3853069029)
  53e000   d537     1550      --- proc/boot/fs-qnx4.so=C:\QNX640\target\qnx6\x86\lib\dll\fs-qnx4.so (2356113523)
  54c000   fbd4     1bf0      --- proc/boot/fs-qnx6.so=C:\QNX640\target\qnx6\x86\lib\dll\fs-qnx6.so (2560413354)
  55c000  12e1e     1e30      --- proc/boot/fs-dos.so=C:\QNX640\target\qnx6\x86\lib\dll\fs-dos.so (2706432591)
  56f000   d819     16f0      ---...
Hi, Oleg,
Did you specify a mount point in your EFS build file using the "mount"
attribute?  If so, I think you should find your EFS mounted, there.  The
default if you don't specify a mount point is something like /fs0p1,
/fs0p2, etc. for each successive combined EFS (/fs0/p0 is the boot image
partition, which is mounted specially).
I could be wrong, but I think that the devf-ram driver should
automatically mount your combined EFSes.
HTH,
Christian
> Hi, Oleg,
> HTH,
> Christian
Hello Christian. Thank you for your reply
When I specify mount attribute to /fs  - >  nothing change.
When I don't specify mount attribute ->  /fs0p1, /fs0p2, /fs0p3  directories system don't create. Maybe problem in boot
script. I attach it.
Attachment: Text qnxbase.bsh 2.12 KB
Hi, Oleg,
Thanks for the boot script -- that explains it.
The boot script doesn't start the RAM driver.  Start up devf-ram and you should see each EFS mounted into a partition as
 I described, previously.
HTH,
Christian
On 05/03/10 01:24 AM, Oleg Gopov wrote:
		Hi, Oleg,
		HTH,
		Christian
	http://community.qnx.com/sf/go/post48873
Christian W. Damus
Software Developer, IDE Team
QNX Software Systems <http://www.qnx.com/>;
Hello Cristian.
Ok. I do , that devf-ram is start when system booted.
As result, fs0p0(fs0p1,fs0p2 ....) directory doesn't created. But, /dev/fs0 and /dev/fs0p0 is created.
Then I read in help -
"You must format and erase a devf-ram partition before you can mount the flash filesystem. e.g. ".
I add command - flashctl -p /dev/fs0p0 -e -f -m.    As result, /fs0p0 directory is created. But it EMPTY. How to mount
to this directory EFS part of my COMBINED image ????????????????
Cristian. Where you are???
Combined EFSes not mounted [was Re: System builder problem]
Hi, Oleg,
Sorry for the delayed reply.
I wouldn't think that initializing a new flash device should be necessary, because devf-ram should already have mounted
your EFSes.
In any case, this doesn't appear to be a system builder problem, so I have changed the subject line.  Hopefully somebody
 that knows more about how these image filesystems work than I do will pitch in to help further.  You might also try
asking about this problem in the filesystems forum; you will find more knowledge there than I can offer.
Cheers,
Christian
	http://community.qnx.com/sf/go/post49062
Christian W. Damus
>  filesystem. e.g. ".
> directory is created. But it EMPTY. How to mount to this directory EFS part of
You cannot if the combined image is being written to a Hard disk drive partition (/dev/hd0t179 as you said).  An EFS
image is not the correct thing to be creating in this situation. Instead you want a qnx6 (also called "Power Fail Safe")
 filesystem image.  I might be wrong, but I do not think the IDE can create a pre-built qnx6 filesystem image.
Instead, on the target, you need to run "mkqnx6fs /dev/hd1t179" to format the qnx6 filesystem on the partition you
created.  There is one mkqnx6fs option which you should be careful about: the -T option.  This is a hint for how many
inodes to create, based on the usage of the disk.  The three options are:
-T desktop
-T media
-T runtime
Select the option that is best for you.
After mkqnx6fs formats the filesystem, you may mount the partition with
mount -tqnx6 /dev/hd0t179  <mountpoint>
And then copy all of your files to the new mountpoint.
David
Post Deleted
> invoke  DEVF-RAM driver. This is driver for flash filesystem.
Yes. and EFS is only for flash.   That is why you must use devf-* to mount an EFS image.
> devices is failed. I read in "Building Embedded systems" document , that I
> Then if I reboot DEVF-RAM driver,  System create /fs0p1 directory , where
I think you are confused about when to use an EFS.  You are describing the process for using an EFS on a target board
which uses NOR flash.  The IFS would be padded to a flash sector boundary, and then the EFS would be "cat" to the end of
 the padded IFS.  At boot time, devf-generic, or some other devf would be started, and would scan the NOR flash to
discover the EFS and mount it.
In your first post, you mention creating a HDD partition.  For this you want to use either the qnx4 or qnx6 filesystem,
and one of the devb-* drivers.  After you fdisk the drive to set the partition size, then use either "dinit" for qnx4
filesystem, or "mkqnxfs" for qnx6 filesystem, targetting the partition you wish to use (either /dev/hd0t79 or /dev/
hd0t179).
You have to burn the image to NOR flash, and then start the correct devf driver for your board.
David
Thank you Davidl. Please tell me, whaat is NOR flash or NAND flash?????
And why when I invoke mkdir command (for example , mkdir /tmp) I have a error
----->   mkdir : /tmp: Function not implemented
But in /fs/hd0-qnx6 directory mkdir is OK. For instance, mkdir /fs/hd0-qnx6/tmp -------->    all OK.
RE: System builder problem
Your /tmp directory might be a symbolic link to /dev/shmem, which looks
like a filesystem but really isn't, and doesn't support the creation of
directories. See:
http://www.qnx.com/developers/docs/6.4.1/neutrino/sys_arch/fsys.html#DEV
SHMEM
Steve Reid (stever@qnx.com)
Technical Editor
> From: Oleg Gopov [mailto:community-noreply@qnx.com]
> Sent: Wednesday, March 17, 2010 2:38 AM
> To: momentics-community
> Subject: Re: System builder problem
> http://community.qnx.com/sf/go/post49695
Could you post output of "mount" command?
Probably your "/" is not serviced by a "filesystem" with mkdir functionality.
PKY
Output of mount command
/dev/hd0t6 on /fs/hd0-dos type dos (fat16)
/dev/hd0t179 on /fs/hd0-qnx6 type qnx6
