Forum Topic - relocation truncated to fit: R_MIPS_PC16: (3 Items)
I am building a project for MIPSLE. I get this error during compilation:
"relocation truncated to fit: R_MIPS_PC16"
I checked and found that the source files (.cpp files) are being built and their object files are created but when these
 are being linked to create a DLL, the above error comes up.
Can somebody help me understand this compilation issue and help me solve it?
Sunil
Re: relocation truncated to fit: R_MIPS_PC16
Which version QNX and QNX  Momentics are You using ?
Is it QNX6.3.2 or QNX640 ?
As far as I can see/tell  this should  fixed with QNX6.4.1 and the appropriate 6.4.1SDP.
If not post your question into the tools forum here:
http://community.qnx.com/sf/discussion/do/listTopics/projects.toolchain/discussion.core_development_tools/
HTH,
Jeevan
Hi Jeevan,
The problem occurs with QNX 6.3. I actually found the solution to this problem. Adding these options on the common.mk
removed the error:
CFLAGS+=-fno-delayed-branch -Wc,-mlong-calls  \
	-Wc,-msoft-float -fno-inline-functions
I am not totally sure what these do but they allow me to proceed with my work :)
Regards
Sunil
