Forum Topic - implementing string class using std namespace string: (2 Items)
I made a string class for wide characters.
this is the code -
using namespace std;
class MyString
public:
wstring wStr;
MyString () {wStr = L"";}
MyString (wstring str) {wStr = str;}
int main()
wstring firstName = L"Vipul";
MyString myStr (firstName);
wprintf(L"%s", myStr.wStr);
return 0;
But it gives error - cannot pass objects of non-POD type class std::wstring through '...'; call will abort at runtime.
What are POD type classes and non-POD type classes?
And how to solve this? I want to make my string class platform independent.
RE: implementing string class using std namespace string
You'll want to use:
 wprintf(L"%s", myStr.wStr.c_str());
thus passing the wchar_t pointer you really want to pass to wprintf.
There's no automatic conversion from a wstring to a wchar_t * and even
if there was the compiler would not know to apply it since functions
such as wprintf that take variable arguments don't provide any type
information them.
A POD type (Plain Old Data) is essentially just a C struct.
So far as I know this is all part of the C++ standard and so will
(should) be platform independent.
