Re: Automatic parameter hints
10/19/2009 9:17 AM
post40221
Hi, Piotr,
The content-assist provided by Eclipse CDT in the C/C++ editor since the
version included in Momentics IDE 4.5 is much improved over the IDE
4.0.1 version. In the more recent CDT editors, the parentheses of a
function call are closed automatically and Ctrl+Space provides tooltip
help for the parameter list. You might consider upgrading to a newer
IDE release.
Even in the current CDT release (6.0), however, the only auto-activation
triggers for content assist are ".", "->", and "::". "(" is not an
option for automatic content-assist. It would probably be confusing to
implement this, as the same parentheses are used for operator scoping in
expressions.
HTH,
Christian
On Mon, 2009-10-19 at 05:02 -0400, Piotr Piwko wrote:
> Hello,
> Is there any option to force the automatic appearance of parameter hints? Now, in order to see a parameter hint of
desired function I have to execute a Content Assistant (Ctrl+Space) and choose name of function.
> I would like see these hints any time when I type a name of function and open parenthesis. By default the Ctrl+Shift+
Space should work, but unfortunately it doesn't.
> I use QNX Momentics IDE version 4.0.1 and C/C++ editor.
> Thank you in advance for any solution.
> http://community.qnx.com/sf/go/post40190
