How did you get QNX 4.25 running under VMWare?
06/02/2009 9:59 AM
post30526
Seems simple, right? After 20 or so hours of trying it just won't work for me.
QNX2 and QNX6 are both running fine in VMWare but QNX4 just won't work.
I've tried every combination of VMWare 4/5/6/6.5, small or large disk size, different BIOS settings (DOS vs. Other large
disk access methods), etc. on three different machines including older dell single core P4 desktops, a newer dell dual
core P4 desktop (allocating a single core to QNX4), and a dell dual core laptop (again, one core for QNX4).
All installs have been done in safe mode with 16 color VGA. Photon comes up and the GUI installer progresses normally,
but...
Two problems always occur. First, it can never read the license floppy. I used 'license' to copy licenses from a working
QNX4 system to a new floppy and it still can't read them.
OK, if the license floppy can't be read it should still boot, right?
Nope. The boot loader starts, the entire series boot progression dots appear (no weird bad block characters or anything)
and then it just stops without displaying any error.
What's the trick here?
Re: How did you get QNX 4.25 running under VMWare?
06/02/2009 10:31 AM
post30538
Hi Ken,
Your floppy is the old style license correct? What happens if you take that floppy and create a raw image of it on
another QNX system using dd
dd if=/dev/fd0 of=/tmp/floppy.img
Then under vmware configuration point the floppy disk to that floppy image. That may help. I too thought that it
should boot past the loader even if no licenses were found, it seems odd that it didn't. Try to get the license thing
worked out first using the floppy image. Another thing to try is the new installation CD:
http://www.qnx.com/download/feature.html?programid=18115
Its pretty much exactly the same as the June 2003 CD, however it adds support for SATA drives via the Fsys.atapi driver,
plus its an ISO that you can download.
Best regards,
Erick
P.S. Kudos for getting QNX2 on Vmware. I admit that has been a burning curiosity of mine for a while, however I just
haven't had the time to test it.
> different BIOS settings (DOS vs. Other large disk access methods), etc. on
> dell dual core P4 desktop (allocating a single core to QNX4), and a dell dual
> and the GUI installer progresses normally, but...
> 'license' to copy licenses from a working QNX4 system to a new floppy and it
> no weird bad block characters or anything) and then it just stops without
06/02/2009 11:01 AM
post30547
> Hi Ken,
My original license is a 720k floppy from QNX 4.01. Our sales rep sent us the QNX 4.25 2003 upgrade package that came
with a 1.4 floppy disk that was labeled "Bootable Install License Disk" and it had a bar code sticker on the back with a
serial number and password. When that floppy didn't work the sales rep sent us a second package and the second floppy
didn't work either. At first I chalked it up to being on a laptop with a USB floppy but licensing didn't work on two
desktop machines that had built in floppy drives either.
> floppy and create a raw image of it on another QNX system using dd
> That may help. I too thought that it should boot past the loader even if no
> thing worked out first using the floppy image.
That's a good idea, I'll give it a try.
> for SATA drives via the Fsys.atapi driver, plus its an ISO that you can
> download.
> Best regards,
> Erick
Thanks, I'll try that too.
> curiosity of mine for a while, however I just haven't had the time to test it.
QNX2 came up easy on a desktop with a 5.25" drive. The hard part was getting all my old QNX2 stuff moved from an ancient
desktop with arcnet over to the VMWare session. Mitchell Shoenbrun helped a lot by donating his QNX2 parallel port ZIP
driver to the cause.
> me.
> newer
> dual
> used
> it
06/02/2009 2:25 PM
post30591
No joy.
The installation process with the 2003 CD behaved identically with the mapped license floppy image as it did with the
disk in the floppy drive - it spins for awhile and then says no license found on disk.
The 2008 CD changed a little. It still couldn't read the license from the drive or mapped image, and it still wouldn't
boot, but instead of hanging after a progression of ..... dots during boot it gave a nice colorful and corrupted video
display before hanging.
Observing the installation steps it sort of seems like only licensed products will get installed - so if it can't read
the license it won't install any packages. If that's the case it would explain why it hangs during boot.
RE: How did you get QNX 4.25 running under VMWare?
06/02/2009 2:30 PM
post30592
Can you install it on real machine? If so do it then afterward you should be able to make an "image" of that disk with
some of the VMware tools.
From: Ken Schumm [mailto:community-noreply@qnx.com]
Sent: June 2, 2009 11:26 AM
To: qnx4-community
Subject: Re: How did you get QNX 4.25 running under VMWare?
No joy.
QNX4 Community Support
http://community.qnx.com/sf/go/post30591
Re: RE: How did you get QNX 4.25 running under VMWare?
06/02/2009 4:52 PM
post30631
Maybe.
The old QNX4 machine could probably be imaged but its hard drive is a lot smaller than I'd like.
> able to make an "image" of that disk with some of the VMware tools.
> To: qnx4-community
> No joy.
> license floppy image as it did with the disk in the floppy drive - it spins
> drive or mapped image, and it still wouldn't boot, but instead of hanging
> corrupted video display before hanging.
> will get installed - so if it can't read the license it won't install any
06/02/2009 5:10 PM
post30634
Ahh however what you could do is then create a new virtual drive boot with the two on the virtual machine and use our
friend QNX_drive_copy
http://quics.qnx.com/cgi-bin/search/usr/free/?srch=QNX_drive_copy&submit=submit&select=1
to copy the contents of the smaller imaged drive to the newly created larger drive.
Best regards,
Erick
> Maybe.
> > To: qnx4-community
> > No joy.
> mapped
> products
06/02/2009 5:25 PM
post30635
Thanks, I'll try fiddling around with that this weekend. My QNX box is at home and it's a monster that I don't want to
haul around.
Thanks for the ideas, I didn't know that VMWare had the ability to image a remote drive.
> two on the virtual machine and use our friend QNX_drive_copy
> submit&select=1
> drive.
> Best regards,
> Erick
> > Maybe.
> be
> > > To: qnx4-community
> > > No joy.
> > mapped
> spins
> > products
06/03/2009 8:51 AM
post30667
> remote drive.
and.. apparently it doesn't have this ability without VMWare tools on the remote machine. To be expected I guess.
08/26/2011 1:07 AM
post88389
Line 68 of that script needs the -b option appended to the [add] command to fdisk.
05/03/2010 3:21 PM
post53449
did U ever get this going? if not, have U considered trying another VM - perhaps VirtualBox or Qemu? i have QNX2 and
QNX4 both running under Qemu on both Linux and MSWindows; can't brag, though, because i don't have anything but the
keyboard and the disk running (not even the mouse) on either OS (Real Job takes up too much time).
i didn't build up either OS from scratch; instead, i imaged existing systems using an IDE-to-USB converter and dd
command. my problem was that the converter automatically uses PATA sector addressing (same as LBA? not sure about
terminology), and both the QNX2 and QNX4 machines were set up to use geometry (CHS) sector addressing; the partition
table was thus pointing to the wrong place (addresses either way are unique, but *different*). solution was to select a
*larger* part of the disk than indicated in partition table:
dd if=/dev/sdc bs=1024 count=400000 | gzip -9c > ...
so that entire portion of disk containing QNX data was included.
