RE: RE: RE: QNX4 - editing sysinit for time zone change
04/15/2009 7:59 AM
post27036
The QNX4 boot doesn't overwrite anything. The sinit program searches for
a /etc/config/sysinit.$NODE file and if it doesn't find one, it looks
for /etc/config/sysinit. I have no idea what you boot process is doing,
but it must be something that you are doing that is causing the file to
be overwritten.
From: Selcuk Cagdas [mailto:community-noreply@qnx.com]
Sent: Tuesday, April 14, 2009 3:15 PM
To: qnx4-community
Subject: Re: RE: RE: QNX4 - editing sysinit for time zone change
The sysinit file I attached is already working. It has the old daylight
time saving rule. I want to change it to new one and make sure change is
there when I reboot the computer. There is two directories called /sys1
and /sys2. Everytime I make changes sysinit file in /sys1, it is
replaced one from /sys2.
> Startrunning is not within the systinit file, so it won't inherit the
> exported time zone. Is this what you problem is?
> Sent: Tuesday, April 14, 2009 2:26 PM
> To: qnx4-community
> Subject: Re: RE: QNX4 - editing sysinit for time zone change
> Thanks for the help. I checked the name of the file. There is no node
> number in the sysinit file name. I also attached the sysinit file if
it
> helps.
> > Are you editing the sysinit.$NODE file, where '$NODE' is your
> machine's
> > node number? The sysinit file doesn't get replaced at boot time.
> > Sent: Tuesday, April 14, 2009 1:39 PM
> > To: qnx4-community
> > Subject: QNX4 - editing sysinit for time zone change
> > I have a QNX4 computer and want to change daylight saving time
rules
> in
> > sysinit file. I can edit the file but every time I reboot sysinit
> file
> > is replaced with the backup ones. How can I Make my changes to
sysinit
> > file permanent. OS is on DiskOnChip.
> > Any help would be appreciated.
> > Selcuk Cagdas
> > QNX4 Community Support
> > http://community.qnx.com/sf/go/post26959
> http://community.qnx.com/sf/go/post26969
http://community.qnx.com/sf/go/post26981
