Forum Topic - Tcpip 5.0:
Tcpip 5.0
Doing an MPEG TS monitor program...Using QNX 4.25 and TCP 5.0
Hitting the limits of TCP, me thinks,  box has to process a  2 multicast
streams of  1340 byte UDP/RTP  every .2 ms for each channel.
Can process up to about 12000 messages / second just fine (4 multicast
sockets/2 channels). After that, messages start getting dropped.
Even reducing to 1 streams still results in issue (sending 20 packets
every 3 ms) results in problem.
It does appear that Tcpip has some finite limit of packets it will queue
onto socket for processing...
Any insight on what Tcpip does ?
Re: Tcpip 5.0
Try increasing the SO_SNDBUF socket option (setsockopt()).  Check
'netstat -pip', 'netstat -pudp'.
