Forum Topic - SOCK_RAW support: (4 Items)
SOCK_RAW support
Trying to link into IGMP protocol.
igmp_socket = socket(AF_INET,SOCK_RAW,IPPROTO_IGMP);
Dont see any data coming back when I do a receive. Tried changing to
IPPROTO_ICMP (and did a ping), event IPPROTO_IP..nada
Any suggestions on what I am screwing up ?
Dave
Re: SOCK_RAW support
You're not passing the correct length to bind().
You're binding "/tmp/sock" and unlinking "/tmp/sock "
(extra space) which is failing silently since you're
not checking the return from unlink() correctly.
Here's a diff.
Attachment: Text diff 981 bytes
Never mind,  Wrong thread...
Hi dave,
Do you solve this problem?
I have the same problem
