Re: The Pg.lx800 usage is empty
07/02/2008 1:21 PM
post9946
I don't believe that information is available anywhere. We will look
to get that corrected in a future driver update. Driver options
are listed below.
Is there a particular problem/issue you are having?
Regards
Mike
AMD Geode LX800 Graphics Driver
Pg.lx800 [options]
Options:
-g X,Y,B Set the graphics driver resolution and # bits per pixel
-d vid,did PCI vendor and device ID of graphics device
-I index PCI index of graphics device
-HN... Access modeswitcher through local name
-R rate Refresh Rate in Hz
-o x,y Set origin of graphics region
-P palette Load inital palette file
-c SW Force software cursor, disable hardware cursor
