The Net.rtl8169 - "cosmetic" problem
05/29/2008 3:26 AM
post8556
I have tested Net.rtl8169 with two Ethernet cards:
deviceID=8167 (onboard adapter)
deviceID=8168 (external PCIe card).
Driver started with the following parameters:
/bin/Net.rtl8169 -d 8168 -m 000004000062 -l4 -v -V 10ec &
detects PCIe adapter and this is OK.
I removed PCIe card and start driver exactly the same as above.
In result onboard card (deviceID=8167) has been detected.
For me in this case, driver should fail and print "Can't find adapter: deviceID=8167).
Looks like that Net.rtl8169 is searching for all known NIC's
even if I force -d option.
Can anybody check this for me ?
Jacek
