Netmask problems for 192.168 network - can't seem to get bigger than
05/26/2008 4:35 PM
post8443
This is with Qnx 4.25 (Socket 4.25C)
I am trying to assign a 16 bit node address space within the 192.168 network but ifconfig does not seem to allow
anything larger than 8 bits for any network starting with 192.
Using a 192.168.0.1/24 network works fine:
ifconfig en1 192.168.0.1 netmask 255.255.255.0 up
ifconfig en1
returns
en1: flags=8863<UP,BROADCAST,NOTRAILERS,RUNNING,SIMPLEX,MULTICAST>
inet 192.168.0.1 netmask ffffff00 broadcast 192.168.0.255
but using 192.168.0.1/16 network forces it back to a /24 network:
ifconfig en1 192.168.0.1 netmask 255.255.0.0 up
ifconfig en1
returns
However it will allow to subnet to finer than a /24 network
I.E. 192.168.0.1/25
ifconfig en1 192.168.0.1 netmask 255.255.255.128 up
ifconfig en1
returns
en1:
inet 192.168.0.1 netmask ffffff80 broadcast 192.168.0.127
Using any other network the netmask I ask for is used: (10.1.0.1/16, for example, also works with 193.0.0.1/16)
ifconfig en1 10.1.0.1 netmask 255.255.0.0 up
ifconfig en1
returns
en1:
inet 10.1.0.0 netmask ffff0000 broadcast 10.255.255.255
This also works for 193.168.0.1/16 which should also technically be a class C network (but is a real address so was
restricted to a private network for testing)
So the Qnx 4.25 networking seems to force any 192.X.X.X network to using a 8 bit class C network space even though the
192.X.X.X network is 256 /24 class C networks that should be able to subnet to up to a /16 network.
Is there any work around to use more than 8 bits of node space with the 192.X.X.X network in QNX?
Re: Netmask problems for 192.168 network - can't seem to get bigger than
05/26/2008 4:49 PM
post8444
> ifconfig en1
> returns
> ifconfig en1
> returns
> I.E. 192.168.0.1/25
> ifconfig en1
> returns
> en1:
> ifconfig en1
> returns
> en1:
You can use a later stack. Earlier versions didn't support
'supernetting', only 'subnetting'. I think the Tcpip manager
supported supernetting as opposed to Socket.
RE: Netmask problems for 192.168 network - can't seem to get bigg
er than
05/26/2008 4:53 PM
post8445
er than
> From: Sean Boudreau [mailto:seanb@qnx.com]
> Sent: Monday, May 26, 2008 4:49 PM
> To: qnx4-community
> Subject: Re: Netmask problems for 192.168 network - can't seem to get
> bigger than
> network but ifconfig does not seem to allow anything larger than 8 bits
> > ifconfig en1
> > returns
> > ifconfig en1
> > returns
> > I.E. 192.168.0.1/25
> > ifconfig en1
> > returns
> > en1:
> > ifconfig en1
> > returns
> > en1:
> class C network (but is a real address so was restricted to a private
> a 8 bit class C network space even though the 192.X.X.X network is 256 /24
> -seanb
'Tcpip' manager is part of TCPRT 5.0. This is a separate package from TCPRT
4.25.
Dave
> QNX4 Community Support
> http://community.qnx.com/sf/go/post8444
