Re: How Windows client can print on QNX4 Samba server?
10/12/2015 2:40 AM
post114626
If start smbd with DEBUG(3) level
#smbd -d3
it is printing/print_generic.c/print_run_command() additional output in log.smbd:
[2015/10/12 10:09:26, 3] printing/print_generic.c:print_run_command(88)
Running the command `/bin/echo "print smbprn.000003.030689 on ps" > /tmp/smbprint.log' gave 81
Return value 81 show the problem in lib/smbrun.c/smbrun():
/* now completely lose our privileges. This is a fairly paranoid
way of doing it, but it does work on all systems that I know of */
become_user_permanently(uid, gid);
if (getuid() != uid || geteuid() != uid ||
getgid() != gid || getegid() != gid) {
/* we failed to lose our privileges - do not execute
the command */
exit(81); /* we can't print stuff at this stage,
instead use exit codes for debugging */
Seems User ID uid и Group ID gid setup problem in become_user_permanently(uid, gid)
How to solve that? Thank you.
> Dear Oleg,
> With yours smb.conf configuration Windows 7 and Windows XP remoute network
> printer install and accept appropriate type of driver ( in Windows XP after
> addition rebooting ).
> > [printers]
> > comment = Print Temporary Spool Configuration
> > path = /var/spool/samba
> > guest ok = Yes
> > printable = Yes
> > browseable = No
> > [qnx_printer]
> > path = /tmp
> > guest ok = Yes
> > printable = Yes
> > postscript = Yes
> > print command = lp %s
> > printer name = 123
> > default devmode = Yes
> On Windows side printing process looking as normal. In the printer spool
> print jobs appear,
> and then removed at the completion of printing.
> On QNX4 samba-server side when printing in /tmp folder trmporary files with
> names smbprn.*.* created and then removed.
> But described in smb.conf
> print command = lp% s
> not performed.
> It is also not carried out wit another option:
> print command = echo "print% s to% p" > /tmp/smbprint.log
> Although issued manually
> #lp filename
> works properly.
> How to make the samba-server to execute the command-line configuration of the
> "print command"?
> Thank you.
> > 2. On Windows PC follow the next steps:
> > Start->Printers and faxes->Add printer->next->a network printer ->choose
> > point ”Connect to a printer or to perform a review printers”->Select
> > your priter->set it Draiver-> try print the document.
> > Let me know about your results.
> > Respectfully,
> > Oleg
> > 6 окт. 2015 г., в 6:53, Leonid Khait <community-noreply@qnx.com> написал:
> > > Hi!
> > >> 1. How did you connect your printer to the QNX4 machine?
> > > The printer is connected to the parallel port of the PC with QNX4 and
> Samba-
> > server.
> > >> 2. How did you configure your printer in the QNX4 (lpd or spooler)?
> > > Printing output is configured by spooler.
> > >> 3. Does the printer print fine directly from the QNX4?
> > > Printout working fine directly from QNX4.
> > >> Also add output following commands from the QNX4 machine:
> > > The outputs with that command are attached.
> > > # sin arg
> > > # ls /dev
