10/23/2014 5:28 AM
post112125
im trying to use MOXA PCI serial card with Fsys.ahci. I have tried different MOXA PCI products but anyone hasnt worked.
After I rebuild the OS image with Fsys.ahci the Dev.ser command frozens my PC. Although if I return to normal Fsys.ata
the PCI-card works normally. Also everything else works perfectly with Fsys.ahci.
The performance of Fsys.ata is so lame that I need to get this work. Any ideas?
10/24/2014 8:22 AM
post112141
Hi Pekka,
If the MOXA PCI serial card and the AHCI SATA controller share one
interrupt line it is possible that the Dev.ser driver loops forever in
the interrupt handler. I've faced such problem once but with very old
Dev.ser driver.
Please attach show_pci -v and sin ar, sin ver, sin ir output.
Pavel
23.10.2014 13:28, Pekka Tuusjärvi:
. After I rebuild the OS image with Fsys.ahci the Dev.ser command frozens my PC. Although if I return to normal Fsys.ata
> QNX4 Community Support
> http://community.qnx.com/sf/go/post112125
> To cancel your subscription to this discussion, please e-mail qnx4-community-unsubscribe@community.qnx.com
10/24/2014 8:45 AM
post112143
Hi Pavel,
here is the pci.txt.
> Hi Pekka,
> Dev.ser driver.
> Regards,
> Pavel
> > Hi,
> MOXA PCI products but anyone hasnt worked. After I rebuild the OS image with
> Fsys.ata the PCI-card works normally. Also everything else works perfectly
> with Fsys.ahci.
> ideas?
10/24/2014 8:46 AM
post112144
10/24/2014 8:47 AM
post112145
10/24/2014 8:47 AM
post112146
10/24/2014 9:50 AM
post112147
Thanks for info.
You have a configuration where Net, AHCI and Dev.ser share one interrupt
line.
As an experiment try to run the Dev.ser driver before the Fsys.ahci
(include and run Dev and Dev.ser from your OS image).
I'll try to reproduce this issue too.
Pavel
24.10.2014 16:45, Pekka Tuusjärvi:
> Hi Pavel,
>> Hi Pekka,
>> Dev.ser driver.
>> Regards,
>> Pavel
>>> Hi,
>> with Fsys.ahci.
>> ideas?
> http://community.qnx.com/sf/go/post112143
10/27/2014 8:47 AM
post112170
Hi Pekka,
I'm trying to reproduce your problem...
For more accurate results please attach sin ir output for your
configuration with Fsys.ata.
Pavel
24.10.2014 17:50, Pavel Kozlov:
> Thanks for info.
> interrupt line.
> Regards,
> Pavel
>> Hi Pavel,
>>> Hi Pekka,
>>> Dev.ser driver.
>>> Regards,
>>> Pavel
>>>> Hi,
>>>> different
>>> image with
>>> normal
>>> perfectly
>>> with Fsys.ahci.
>>>> work. Any
>>> ideas?
>>>> qnx4-community
10/28/2014 2:57 AM
post112187
Hi Pavel,
here is the sin ir with Fsys.ata.
11/05/2014 4:17 AM
post112274
Hi Pekka,
We have reproduced your issue here. We're working on this issue. When the fix will be prepared, I'll let you know.
28 окт. 2014 г., в 9:57:54, Pekka Tuusjärvi <community-noreply@qnx.com> написал:
> Hi Pavel,
> http://community.qnx.com/sf/go/post112187
> <sin_ir.txt>
12/01/2014 6:52 AM
post112488
Hi!
Any news on this one?
12/01/2014 8:53 AM
post112489
Hi Pekka,
I remember this issue. Unfortunately, the fix is not ready yet.
01 дек. 2014 г., в 14:52:36, Pekka Tuusjärvi <community-noreply@qnx.com> написал:
> Hi!
> http://community.qnx.com/sf/go/post112488
12/19/2014 3:54 AM
post112747
Hi Pekka,
Please try attached Dev.ser driver.
cksum Dev.ser.tar.gz
3280607655 15535 Dev.ser.tar.gz
With best regards,
Vladimir
12/19/2014 4:02 AM
post112748
Also please try attached Fsys.ahci driver.
This version checks interrupt status in interrupt handler and if it's not an ahci
interrupt it skips it without masking/unmasking the interrupt.
cksum Fsys.ahci.tar.gz
3556589980 82115 Fsys.ahci.tar.gz
With best regards,
Vladimir
01/05/2015 4:04 PM
post112829
Thank you very much. I will try when I get back to my office. :)
01/14/2015 8:01 AM
post112933
Hello, I get archive is corrupt error If i try to extract archive?
01/14/2015 8:33 AM
post112934
Hi Pekka,
Seems like both archives are broken.
cksum Dev.ser
1146694106 29093 Dev.ser
Best regards,
Vladimir
01/14/2015 8:45 AM
post112935
And
Fsys.ahci driver
cksum Fsys.ahci
2031912476 145562 Fsys.ahci
01/14/2015 9:30 AM
post112937
Hi Pekka!
Unfortunately, it seems like community portal engine issue. All tar.gz archives are downloading double gzipped. To
unpack double gzipped archive you should ungzip it twice:
$ zcat Fsys.ahci.tar.gz | zcat | tar xf
Or you can fix downloaded archive:
$ zcat Fsys.ahci.tar.gz > Fsys.ahci_fixed.tar.gz
I recommend using archives to transfer files. In this case file attributes are preserved.
14 янв. 2015 г., в 16:01:52, Pekka Tuusjärvi <community-noreply@qnx.com> написал:
> http://community.qnx.com/sf/go/post112933
01/20/2015 1:58 AM
post113001
> Hi Pekka!
> archives are downloading double gzipped. To unpack double gzipped archive you
> preserved.
> Respectfully,
> Oleg
Hi and thanks for the info. The fix seems to work fine in my test pc. So big thanks everyone who participated to fix
this problem.
