Re: Process blocked (all threads) by devc-pty?
03/11/2014 9:15 AM
post109344
Thread one is blocked on a mutex currently locked by thread 3:
thread 3 didn't unlock before asking work of devc-pty (read(),
write() etc...). Thread 2 is probably blocked in poll() or
select(). A backtrace of all the threads will be more definitive.
BTW this isn't a qnx4 question.
On Tue, Mar 11, 2014 at 12:53:19PM +0400, Олег Большаков wrote:
> Hi Andrew,
> This is support forum for QNX 4.25 RTOS, not for BlackBerry. Please repost your question in suitable BlackBerry
Developer Forum:
> http://supportforums.blackberry.com/t5/Developer-Support-Forums/ct-p/blackberrydev
> Respectfully,
> Oleg
> 10.03.2014, в 18:31:57, Andrew Mackie написал:
> > A developer is encountering an issue wherein a BB10 process appears to be blocked for a period of several minutes.
> > No threads are responding. I added a heartbeat thread to log the status of threads every second, and captured thread
states pre-and post-block.
> > The process is an automated test framework to test that the installer is working by installing apps, such as Music
Store. It receives instructions over PPS from another process, attempts an install and returns the results in the same
manner. I'm relying on another user to reproduce this, as I cannot locally. The "result" seems to be successful (music
store installed), but the block time is excessive (6.5 minutes in this case).
> > Checking pidin on a subsequent run, we're seeing the following stats for the process:
> > pid tid name prio STATE Blocked
> > 62406885 1 ./InstallerApi 10r MUTEX (0x80c2fcc) 62406885-03 #1
> > 62406885 2 ./InstallerApi 10r SIGWAITINFO
> > 62406885 3 ./InstallerApi 10r REPLY 4681795
> > Which seems to point to 4681795 as the culprit:
> > 4681795 1 base/sbin/devc-pty 20r RECEIVE 1
> > which according to the docs is the pty (pseudoterminal?) manager. I'm not sure if this is a wild goose chase, or is
accurate, and if so, why devc-pty would be completely blocking all process threads from executing.
> > Slog is attached.
> > Additional info
> > Thread status - Just before blocking (heartbeat from process log)
> > Tue Feb 11 07:14:59 2014 :: (1-Install) :: INFO: Name: Main tid: 1 flags: 0 why: 0 what: 0 ip:
18051888 sp: 133217656 stkbase: 132694016 tls: 133221984 stksize: 528384 tid_flags: 0 priority: 10 real_priority:
10 policy: 2 state: 6 syscall: 11 last_cpu: 0 timeout: 0 last_chid: -1 start_time: 1392102846808986439 sutime:
648628428 extsched: reserved2: 7f0beb8
> > Tue Feb 11 07:14:59 2014 :: (1-Install) :: INFO: Name: AI listener thread tid: 2 flags: 0 why: 0 what: 0 ip:
18052880 sp: 134097396 stkbase: 133963776 tls: 134098528 stksize: 135168 tid_flags: 67108864 priority: 10 real_priority:
10 policy: 2 state: 11 syscall: 32 last_cpu: 1 timeout: 16779264 last_chid: -1 start_time: 1392102849108394360 sutime:
200430213 extsched: reserved2: 7f0beb8
> > Tue Feb 11 07:14:59 2014 :: (1-Install) :: INFO: Name: Work thread tid: 3 flags: 0 why: 0 what: 0 ip:
18053992 sp: 134478776 stkbase: 134348800 tls: 134481920 stksize: 135168 tid_flags: 67239936 priority: 10 real_priority:
10 policy: 2 state: 12 syscall: 75 last_cpu: 0 timeout: 16781312 last_chid: -1 start_time: 1392102898768756582 sutime:
24172488 extsched: reserved2: 7f0beb8
> > Thread status - Just after blocking (from app)
> > Tue Feb 11 07:21:30 2014 :: (1-Install) :: INFO: Name: Main tid: 1 flags: 0 why: 0 what: 0 ip:
18051888 sp:...
