03/18/2013 7:41 AM
post99954
Thank you for the reply Oleg.
Can you provide any details on the correct options for the crt.node file.
I tried the -o option by passing these options to the driver using the advanced tab in the Photon display configuration
utility.
This did not work.
Are there other options I should be using?
Should I be editing the crt.node file directly?
This is the first line in the crt.node file:
Null.ms;Pg.i830 -g800x600x32 -d0x8086,0x3582 -I0 -HNqnx/crt;#800,600,32,200,0CBDr,i830 - Intel 82830/82845/82852/82855/
82865
Thanks very much for your help.
Larry
