Forum Topic - critical issue about QNX need for help: (2 Items)
I am using QNX IPsec setkey. Seems QNX only support SHA1.
Does QNX IPsec support SHA256?
I checked the manual for IPsec and found no information.
Thanks a lot in advance!
Re: critical issue ... {SHA-256 supported?}
SHA-2 is a generic reference to: SHA-224, SHA-256, SHA-384, SHA-512.
Those are HMAC algorithms indicated as arguments to the function setkey (the utility to “Manually manipulate the IPsec
SA/SP database”).
Please look for the section “Algorithms for protocol” in the page.
http://www.qnx.com/developers/docs/6.5.0/index.jsp?topic=/com.qnx.doc.neutrino_utilities/s/setkey.html
Parameter <aalgo> is indicated as two different parameters of setkey. See the parameters for authentication and
encryption:
-A aalgo key
    Specify an authentication algorithm (aalgo) for the ah ...
-E ealgo key
    Specify an encryption algorithm (ealgo) for the esp ...
All of the SHA-2 appear to be there for Authentication.
-Fernando Gonzalez
