10/28/2010 10:22 AM
post72812
I also forgot to mention, I tried using the QNX 4.25 2009 boot floppy available on the website here, but this did not
work, it does not boot up properly.
10/28/2010 10:27 AM
post72814
You can change your disk/CD names as follows:
Edit your /boot/build/install.$node file
Change the Fsys.atapi line to read just $ /bin/Fsys.atapi
Change the mount line to read $ /bin/mount p /dev/hd0 /dev/hd0t77 /
cd /boot
make b=install.$node
cp images/install.$node /.boot
Then you must edit your /etc/config/sysinit.$node file and change all
references to hd0.0 to hd0 and all references to cd0.0 to cd0.
Reboot your machine.
Hope this helps.
On 10-10-28 10:18 AM, "Omar Sarwar" <community-noreply@qnx.com> wrote:
> Hi folks,
> I am hoping someone here with a wealth of QNX knowledge will be able to help
> me out in a tricky situation here.
> I've ordered a new PC, Advantech Motherboard Q35 Chipset AIMB-766 and IDE Hard
> Drive.
> I was originally trying my floppy disk version of QNX 4.25A which consists of
> 5 or 6 floppy disks to install the operating system.
> However, upon using the Boot Disk and getting to the bit where it trys to find
> the hard drive. It says it couldn't auto detect the adapter, so I select
> Fsys.eide, after which an error message appears "No Adaptors Found!" and
> continues to display "Waiting for /dev/hd0 to initilize" until it asks to
> reboot.
> I tried using the QNX 4.2 RTOS CD which installs QNX fine and detects the hard
> drive and cd rom drive fine. (Seems to use Fsys.atapi)
> However, the naming convention for the HD and CD rom are different.
> CD-ROM = cd0.0
> Hard Drive = hd0.0
> It is important that the hd0.0 is hd0 and cd0.0 is CD0 due to the software
> that is required to be installed.
> Is it possible to do this?
> But the big bonus for me is, would it be possible to somehow get the
> fsys.atapi onto a bootable QNX floppy and be able to boot up qnx with that and
> then continue installing from the remaining floppy disks?
> Hopefully I've made sense, any help is appreciated!
> QNX4 Community Support
> http://community.qnx.com/sf/go/post72810
Hugh Brown (613) 591-0931 ext. 2209 (voice)
QNX Software Systems Ltd. (613) 591-3579 (fax)
175 Terence Matthews Cres. email: hsbrown@qnx.com
Kanata, Ontario, Canada.
K2M 1W8
