Forum Topic - Network Support (Part 2): (4 Items)
Good Morning QNX Community,
   I have a question regarding network of multiple ports for a QNX4 machine I am once again building.  I currently have
two network cards installed.  One that is a 3com and the other which is located directly on the mother board.  After
doing some tweaking, the 3com works perfectly.  However, I would also like to get the network adapter on the motherboard
 working as well.  I did a sin that displays the 'Net' and the 'Net905' e.g the 3com adapter working perfectly.  netstat
 -in shows that en1 is currently being used by this.
Typing show_pci gives me this:
PCI version    = 2.10
Vendor ID      = 8086h, INTEL CORPORATION
Device ID      = 1132h,
PCI index      = 0h
                 MEM @ e0000000h MEM @ e8000000h
PCI Int Pin    = INT A
Interrupt line = 9
Class          = Mass Storage (IDE)
Device ID      = 244bh,
PCI index      = 0h
                 IO @ f000h
PCI Int Pin    = NC
Interrupt line = 0
Class          = Network (Ethernet)
Device ID      = 1229h, 82557/8 Ethernet Adapter
PCI index      = 0h
                 MEM @ e7101000h IO @ a400h MEM @ e7000000h
PCI Int Pin    = INT A
Interrupt line = 5
Device ID      = 2449h,
PCI index      = 0h
                 MEM @ e7100000h IO @ a000h
PCI Int Pin    = INT A
Interrupt line = 10
Class          = Mass Storage (SCSI)
Vendor ID      = 9005h,
Device ID      = 80h,
PCI index      = 0h
                 IO @ 9000h MEM @ e6400000h
PCI Int Pin    = INT A
Interrupt line = 11
Vendor ID      = 10b7h, 3Com
Device ID      = 9200h,
PCI index      = 0h
                 IO @ 9400h MEM @ e6401000h
PCI Int Pin    = INT A
Interrupt line = 12
It looks like QNX recognizes the ethernet port not in use, however,  I believe my biggest issue is how to assign a new
en to my motherboard ethernet card 82557??  Does anyone have any input on how I can go about this?
Thank you.
Re: Network Support (Part 2)
I forgot to add that I also keep getting the error: Register with Net Manager failed.
First of all, you will have to start 'Net -d3 &' as you have 3 network
adapters.
Next, start 'Net.ether905 &'
Then start 'Net.ether82557 -V8086 -D1229 -l2 &'
Then start 'Net.ether82557 -V8086 -D2449 -l3 &'
> am once again building.  I currently have two network cards installed.  One
> After doing some tweaking, the 3com works perfectly.  However, I would also
> like to get the network adapter on the motherboard working as well.  I did a
> perfectly.  netstat -in shows that en1 is currently being used by this.
> PCI version    = 2.10
> Device ID      = 1132h,
> PCI index      = 0h
> PCI Int Pin    = INT A
> Interrupt line = 9
> Device ID      = 244bh,
> PCI index      = 0h
>                  IO @ f000h
> PCI Int Pin    = NC
> Interrupt line = 0
> PCI index      = 0h
> PCI Int Pin    = INT A
> Interrupt line = 5
> Device ID      = 2449h,
> PCI index      = 0h
> PCI Int Pin    = INT A
> Interrupt line = 10
> Vendor ID      = 9005h,
> Device ID      = 80h,
> PCI index      = 0h
> PCI Int Pin    = INT A
> Interrupt line = 11
> Device ID      = 9200h,
> PCI index      = 0h
> PCI Int Pin    = INT A
> Interrupt line = 12
> my biggest issue is how to assign a new en to my motherboard ethernet card
> Thank you.
> QNX4 Community Support
> http://community.qnx.com/sf/go/post59522
Kanata, Ontario, Canada.
K2M 1W8
Thank you sir.  It worked!  Very much appreciative.
> adapters.
l3 &'
> I
> > PCI version    = 2.10
> > Device ID      = 1132h,
> > PCI index      = 0h
> > PCI Int Pin    = INT A
> > Interrupt line = 9
> > Device ID      = 244bh,
> > PCI index      = 0h
> >                  IO @ f000h
> > PCI Int Pin    = NC
> > Interrupt line = 0
> > PCI index      = 0h
> > PCI Int Pin    = INT A
> > Interrupt line = 5
> > Device ID      = 2449h,
> > PCI index      = 0h
> > PCI Int Pin    = INT A
> > Interrupt line = 10
> > Vendor ID      = 9005h,
> > Device ID      = 80h,
> > PCI index      = 0h
> > PCI Int Pin    = INT A
> > Interrupt line = 11
> > Device ID      = 9200h,
> > PCI index      = 0h
> > PCI Int Pin    = INT A
> > Interrupt line = 12
> believe
> > Thank you.
> K2M 1W8
