Forum Topic - QNX 4 on large drives: (5 Items)
Has anybody had any success installing qnx 425 on 250Gb hard drives.
I am trying to install WD2500 SATA drives without much success.
I cant get it to detect > 137Gb
Re: QNX 4 on large drives
Have you tried the lba48 option.
Im unsure how to use lba48.
Is that part of  Fsys.ATAPI  or Fsys.eide.
I have installed QNX on SATA disk Samsung 250 Gb, controller Intel 82801EB (ICH5) in a mode of compatibility. The size
QNX partition 80Gb. I used standard install disk QNX RTOS v.4.25E. At this stage standard Fsys.eide has proved to be
perfectly. After replacement in kernel Fsys.eide on Fsys.atapi from archive QNX4-atapi_20050429.tar.gz (a line build
file $ \bin \Fsys.atapi fsys-Ndsk1-n0=hd0.-n5=cd0. atapi lba48) the system also was loaded. However after settig in BIOS
 " extended SATA " mode (are simultaneously connected 4 PATA and 2 SATA the device) Fsys.atapi at loading not find out
the hard disk, and mount has not mounted file system. The second trouble was found out after creation of sections for XP
. mount has informed, that the size of my disk of 268435455 blocks (fff'ffffh), and partition FAT32 borrows space from
the block 239951943 up to 280912590 and could not mount ANYTHING!!! QNX it was not loaded. Probably someone has solved
these questions, Please I ask to answer.
I am using (example for detect a large secondary disk): Fsys.atapi fsys -Ndsk1 -n0=hd1 atapi ioport=0x170,irq=15,master=
lba48
No problem with 300Gb disks
Good luck
