Forum Topic - Drawing Custom Widgets: (3 Items)
I am creating custom widgets and found that when testing these widgets, I noticed that the draw order has an effect on
some widgets.
The widgets are updated every 1/2 second via a callback from a PtTimer.
So this is the problem.  I created 5 custom widgets.  I can add all 5 custom widgets to a window module and build and
run the application.  Depending on the draw order of these widgets, only certain widgets will appear.  Those that do not
 appear will appear after I force a redraw (damage the widget).
So lets say widget number 5 is causing this problem.  If the draw order is 1 - 2 - 3 - 4 - 5, all widgets will appear.
If the draw order is 4 - 2 - 5 - 3 - 1, widgets 3 and 1 will not be drawn until I force a redraw.  Widgets 4, 2 and 5
will appear.
Right now I have 2-ish work arounds:
1. Always place widget 5 in a PtDBContainer (only 1 per PtDBContainer) and
2. Always draw widget 5 last, however, this still corrupts the widgets - so this really isn't a work-around.
Neither of these are a good option for me.  Has anyone experienced this? Could anyone offer some advice to help solve
this problem?
Chris
Re: Drawing Custom Widgets
I don't know for sure... but it seems to me that perhaps clipping/multiclipping/translations are not properly set/
restored by some of your widgets' draw function. Could you post the code (if it is not too large)?
Misha,
Thanks for the heads up.  That was exactly the case.
In my draw function I had a PtClipAdd( widget, &canvas ) function call and it was not followed with a PtClipRemove().  I
 added this function call and all widgets drawn after "widget 5" are now displayed.
Thanks for your quick response.
Chris
