Forum Topic - Hard disk serial number: (5 Items)
Is there any way I can read the manufacturer's hard disk serial number?
Re: Hard disk serial number
BTW I want to use C/C++/Assembly & watcom compiler.
you have to write this function itself.
On the basis of ATA specification just send a proper command to the  controller,
read and analyse response.
Jacek
> controller,
Jacek,
I have the same issue,
do you have any code that shows how to achieve this?
Won't there be any issue with the devb-eide
talking to the controller at the same time?
Would it not be better to talk to the devb-eide server instead?
Hi Martin,
Yes, I have implemented some ATA low level routines.
Not, if you do that smart and carefully.
As far as I remember under QNX4 there is not possible to get such
information from a block driver.
The devb-eide is QNX Neutrino driver.
I'm not sure if devb-eide can provide this data as well...
Jacek
