Forum Topic - ERROR : QNX SDP6.4.1 : Exception in thread "main" java.lang.NoClassDefFoundError: run:
good evening:
we have purchased a beautiful box set of QNX SDP 6.4.1 and would like to install it on Linux as well as on Widnows. it
contains the DVD that holds the installers for all supported platforms.
the Windows installer works very well and installs QNX SDP correctly on Windows 7.
however, when i copied the Linux installer on to Ubuntu, i get an odd Java error. pls see detailed error log below.
Running InstallShield Wizard...
any ideas why we use Java for installation and then get all these ridiculous errors?
8-) it is illogical.
usually, on Unix / Linux, you only need a simple program that extracts individual files from a compressed package and
that copies these files into the appropriate location. why use Java for something like that? even a simple shell script
will set any required environment variables.
the same error occurs on Ubuntu (java 1.5) and on SUSE Linux (java 1.6).
good night,
Aaron
gj-suse91:/home/aaron> ./qnxsdp-6.4.1-200905201802-linux.bin
Initializing InstallShield Wizard...
Preparing Java(tm) Virtual Machine...
{ Alan Turing, Fritz Gerlich, Robert Oppenhimer, how Zapruder, Rodney King? }
Attachment: Image ubuntu_qnx641_install_error.png 39.32 KB
Re: ERROR : QNX SDP6.4.1 : Exception in thread "main" java.lang.NoClassDefFoundError: run
Hi Aaron,
What version of Ubuntu and Suse are you using?  Are these 64 or 32 bit systems?
The installer is setup to use Sun JVM 1.5.0 which is bundled in.  It looks like java 1.6 which is in the PATH being
picked up and used by the installer.  That might be the issue.
Try the following workaround to extract java from the installer, and then use it to launch the installer:
mkdir tmp-java
cd tmp-java
../qnxsdp-6.4.1-200905201802-linux.bin -is:extract
./linux-sun-1.5.0.bin
bin/java -cp qnx_linux_setup.jar run
Hope this helps,
Natalia
Aaron,
Could you try the following (note, the last command is different from the original instructions):
mkdir tmp-java
cd tmp-java
bin/java -jar qnx_linux_setup.jar
It is a different way to launch the installer.
If you're still getting the same error, please attach the screen shot of the terminal where you're executing these
commands.
Natalia
Hello Aaron,
could you tell me which version of Ubuntu you are running? I am currently running a 8.04LTS (64Bit) and had no problems
installing the IDE apart from making sure that I am root and to call the installation script (.bin) manually.
On a side note I was using sudo and did not log in as root, which may explain some things too. 'su -' changes into the
complete root environment, which also means that the standard environment variobles, especially PATH and LD_LIBRARY_PATH
 are set to the respective single-user/maintenance values.
I also was not running the script from the CD but copied it from the CD into my home directory. Apparently the gvfs is a
 little tricky in those things.
The error message itself tells us that the VM cannot find the installer classes, which is slightly confusing but not
unseen. Furthermore the installer looks for an installed VM but seems to use the internal one nonetheless.
Regards and greetings,
Bjoern Weber
Technical Account Manager / R&D
-- QNX Software Systems GmbH & Co. KG Tel: +49 (511) 94091-450 Am Listholze 76 Fax: +49 (511) 94091-199 30177 Hannover
Germany http://www.qnx.com
-- QNX Software Systems GmbH & Co. KG Sitz der Gesellschaft: Karlsbad - Registergericht: Mannheim HRA 361207
Komplementaerin: QNX Software Systems Management GmbH Sitz der Gesellschaft: Hannover - Registergericht: Hannover
Geschaeftsfuehrung: Dr. Tim Bast - Norbert Struck – Michael Michalyshyn - Edwin Summers
good evening Bjoern, Natalia, Sonke:
i was ill Mon & Tue with (not swine) flu.
> currently running a 8.04LTS (64Bit) and had no problems installing
i have updated the ticket after i tried out Natalia's instructions.
after unpacking the package using -is:extract, i dont find any
QNX641 installer JAR.
cheers!
Aaron
  Orient Express trains
  http://www.orient-express.com/collection/trains/trains.jsp
good morning Sonke, Bjoern, Natalia:
i apologize, but i had not copied the QNX Linux installer JAR into the
directory that contained the BIN.
i will try this again and let you know how it goes.
Bjoern, i am amazed at the quickness of your response. thank you.
have a good day,
Aaron
{ Orient Express trains http://www.orient-express.com/collection/trains/trains.jsp }
IMPORTANT UPDATE
i didnt realize that you need 2 files for the install, the BIN and the JAR. i had not copied the JAR and so i erred and
got the CRYPTIC Java error message that left me more confused.
i will retry the install with the required JAR and let you know how it goes.
Aaron
hello:
i installed QNX641 on openSUSE and it works. so, the only reason it didnt work before is because i has copied only the
SDP bin file and not the setup JAR.
you need both qnx_linux_setup.jar  qnxsdp-6.4.1-200905201802-linux.bin in the same directory when you start the install.
cheerios!
Aaron
