                    Re: Rhapsody, QNX, and Photon Application Builder
                 10/27/2009 5:55 AM
                post40740
                Hi !
We also firstly planned to use photon with Rhapsody and QNX. As Photon provide C source code, it is possible to generate
 a resource manager that will be called by the main application (generated by Rhapsody). You can also share memory
between the two applications to exchange data. At first sight, it appears difficult to generate photon code in Rhapsody
(you need to design a wrapper class for Photon functions).
Finally we decided to use Qt which is now proviced with LGPL licence, graphic application and main application will
communicate each-other using TCP/IP communication trough local loopback.
