Cannot display photon window from QNX
05/20/2009 11:46 AM
post29749
I'm running Neutrino 6.4.0 on a Virtual machine, and having problems getting the Photon graphical interface to load.
When I run "ph" at the QNX command line, I get the following error:
# ph
Unable to start graphics driver(s)
The following is some useful info I retrieved based on comments in another post. Unfortunately, that post didn't
complete and no solution was listed, so I'm hoping some can help me out here.
# sloginfo
May 20 16:40:48 1 8 0 phfont.so: init...
May 20 16:40:48 1 8 0 phfont.so: initialized.
May 20 16:40:48 1 8 0 phfont.so: '/dev/phfont[<32|64>]' server installed.
May 20 16:40:48 6 8 0 pci_init: found PCI device 15ad:405
May 20 16:40:48 6 8 0 VMWARE svgaid=0x90000002
May 20 16:40:48 2 8 200 io-display: driver doesn't support, or not configured for "argb8888" at 1024x768, 60Hz
May 20 16:40:48 2 8 0 /usr/photon/bin/io-graphics: gf_dev_attach('/dev/io-display/15ad,0405,0'): gf errno 4
# ls -l /dev/io-display/
total 0
crw-rw---- 1 root root 0, 1 May 20 14:09 15ad,0405,0
# pci -v
Class = Display (VGA)
Vendor ID = 15adh, VMware Inc
Device ID = 405h, Abstract SVGA II Adapter
PCI index = 0h
Class Codes = 030000h
Revision ID = 0h
Bus number = 0
Device number = 15
Function num = 0
Status Reg = 290h
Command Reg = 7h
Latency Timer = 40h
Cache Line Size= 8h un-cacheable
PCI IO Address = 10f0h length 16 enabled
PCI Mem Address = d0000000h 32bit length 134217728 enabled
PCI Mem Address = d8000000h 32bit length 8388608 enabled
Subsystem Vendor ID = 15adh
Subsystem ID = 405h
PCI Expansion ROM = 0h length 32768 disabled
Max Lat = 0ns
Min Gnt = 0ns
PCI Int Pin = INT A
Interrupt line = 9
CPU Interrupt = 9h
Capabilities Pointer = 40h
Capability ID = 0h - Unknown
Capabilities = 0h - 0h
Dan
