Forum Topic - Intel 82574 Ethernet Controller Support: (1 Item)
Does anybody know if there is a QNX driver available for Intel's 82574L Gigabit ethernet controller?
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=3023&lang=eng
Here is the relevant snippet from my pci -vvv output:
Class          = Network (Ethernet)
Device ID      = 10d3h,  82574L Gigabit Network Connection
PCI index      = 0h
Class Codes    = 020000h
Revision ID    = 0h
Bus number     = 4
Device number  = 0
Function num   = 0
Status Reg     = 10h
Command Reg    = 107h
	I/O space access enabled
	Memory space access enabled
	Bus Master enabled
	Special Cycle operations ignored
	Memory Write and Invalidate disabled
	Palette Snooping disabled
	Parity Error Response disabled
	Data/Address stepping disabled
	SERR# driver enabled
	Fast back-to-back transactions to different agents disabled
BIST           = 0h Build-in-self-test not supported
Latency Timer  = 0h
Cache Line Size= 10h un-cacheable
PCI Mem Address = f0280000h 32bit length 131072 enabled
PCI Mem Address = f0200000h 32bit length 524288 enabled
PCI IO Address  = 2000h length 32 enabled
PCI Mem Address = f02a0000h 32bit length 16384 enabled
PCI Expansion ROM = 0h length 262144 disabled
Max Lat        = 0ns
Min Gnt        = 0ns
PCI Int Pin    = INT A
Interrupt line = 10
CPU Interrupt  = ah
Capabilities Pointer = c8h
Capability ID        = 1h - Power Management
Capabilities         = 4822h - f002000h
Capability ID        = 5h - Message Signaled Interrupts
Capabilities         = 80h - 0h
Capability ID        = 10h - PCI Express
Capabilities         = 1h - 8cc1h
Capability ID        = 11h - MSI-X
Capabilities         = 4h - 3h
Device Dependent Registers:
0x040:  0000 0000 0000 0000   0000 0000 0000 0000
0x0a0:  1100 0400 0300 0000   0320 0000 0000 0000
0x0b0:  0000 0000 0000 0000   0000 0000 0000 0000
0x0c0:  0000 0000 0000 0000   01d0 2248 0020 000f
0x0d0:  05e0 8000 0000 0000   0000 0000 0000 0000
0x0e0:  10a0 0100 c18c 0000   1028 0900 111c 0300
0x0f0:  0000 1110 0000 0000   0000 0000 0000 0000
