                    RE: RE: Change /tmp to what my windows have in %TEMP%
                 02/02/2009 4:47 PM
                post21257
                Max,
 I can confirm that there is nothing under HKEY_LOCAL_MACHINE, i'm also using Vista64.  I did a search of the string
Cygnus in all of the registry and that is all I could find.
> From: Max Feil [mailto:community-noreply@qnx.com]
> Sent: February-02-09 4:45 PM
> To: general-community
> Subject: RE: RE: Change /tmp to what my windows have in %TEMP%
> Please double check. Any Cygwin application will always add the
> "HKEY_LOCAL_MACHINE\SOFTWARE\Cygnus Solutions\Cygwin\mounts v2" key to
> the registry. It has to be there if appbuilder was ever run before.
> And as per Mario's note, there is a duplicate of this key under
> HKEY_CURRENT_USER but in my tests this one was not used. You need the
> one under HKEY_LOCAL_MACHINE.
> Max
> From: Henrik Holmberg [mailto:community-noreply@qnx.com]
> Sent: Monday, February 02, 2009 4:39 PM
> Subject: Sv: RE: Change /tmp to what my windows have in %TEMP%
> Hi!
> The problem is that I don't have that Cygnus part in my register.
> I'm running Vista Ultimate x64 BTW
> /Henrik
> -------Originalmeddelande-------
> Från: Max Feil
> Datum: 2009-02-02 21:01:01
> Till: general-community
> Ämne: RE: Change /tmp to what my windows have in %TEMP%
> Hi Henrik. The location of the /tmp folder is determined by the cygwin
> "/" mount point. By default Cygwin puts this at the root of the C
> drive.
> You can change this location by using "regedit" and editing the
> following Windows registry key:
> 1) HKEY_LOCAL_MACHINE\SOFTWARE\Cygnus Solutions\Cygwin\mounts v2
> 2) Add a new key under this one called "/" (without the quotes of
> course)
> 3) Add a new DWORD value named "flags" under the new key, and give it a
> value of A (which is 10 in decimal)
> 4) Add a new string value named "native" under the new key, and give it
> a value of the directory where you want /tmp to be created, for example
> the contents of your %TEMP%.
> Good luck, and as recommended by Microsoft please back up your registry
> before editing it in case something goes wrong.
> Max
> P.S. You can see a sample screenshot of regedit showing correct values
> here:
> Sent: Saturday, January 31, 2009 12:27 PM
> Subject: Change /tmp to what my windows have in %TEMP%
> Hi!
> I don't want a lot of files i C:\ so I want to change the temp folder
> created by Applicationbuilder when it starts.
> How do I change that folder?
> Found something in the ph-file but what do I change and to what?
> /Henke
> http://community.qnx.com/sf/go/post21192
> http://community.qnx.com/sf/go/post21246
> http://community.qnx.com/sf/go/post21254
> http://community.qnx.com/sf/go/post21256
