Forum Topic - open a device from the same process?: (3 Items)
I am trying to unit test a simple resource manager.  The unit test process creates the resource manager just fine and I
can see it registered in /dev/mydevice.
However, when I try to use open to access the device "/dev/mydevice" after creation, I get an error saying no such file
or directory.
Is it not possible to open a device from the same process that created it?
If I move the resource manager code and start it as a separate process in the system, everything works fine.
Thoughts,
Mike
Re: open a device from the same process?
On Thu, Oct 30, 2008 at 01:31:37PM -0400, Michael Cranston wrote:
> Hello,
I can see it registered in /dev/mydevice.
file or directory.
> Thoughts,
Look at the _RESMGR_FLAG_SELF flag in resmgr_attach().
Thanks.  That did the trick.
Not sure how I missed that in the manual......
