Forum Topic - USB/Network to serial converter support:
Does QNX support any of the devices that convert from USB to serial? How about network-to-serial?
I am interested in connecting multiple serial devices to a laptop, and am considering the Comtrol USB-serial hub,
Comtrol network-serial hub, or perhaps using several individual USB-serial converters. Any info or advice would be
appreciated.
Kevin
Re: USB/Network to serial converter support
RE: USB/Network to serial converter support
Network to serial sounds a bit strange... Are you thinking of something
that does Ethernet to serial or something like PPP which is network over
serial?
	Robert.
From: Kevin Miller [mailto:community-noreply@qnx.com]
Sent: Thursday, October 23, 2008 3:41 PM
To: general-community
Subject: USB/Network to serial converter support
am considering the Comtrol USB-serial hub, Comtrol network-serial hub,
advice would be appreciated.
Kevin
General
http://community.qnx.com/sf/go/post15470
Re: RE: USB/Network to serial converter support
Ethernet-to-serial coversion.  We want to control three devices (or maybe more) that only accept serial input, using a
laptop which, at most, has only one serial port. I was considering something like this:
http://www.comtrol.com/uploads/Bo/oo/BoooV7Sf530d2NillDQWmQ/99448_0_DM_RTS_8Port_RoHs_LT1251D.pdf
RE: RE: USB/Network to serial converter support
No luck with us supporting that out of the box (i.e. Ethernet to
multi-serial).  That's a proprietary implementation.  If they provide
the appropriate packet formats, it's likely straight forward in terms of
making it work, but that would be development on your side.
	Robert.
Sent: Thursday, October 23, 2008 4:52 PM
Subject: Re: RE: USB/Network to serial converter support
maybe more) that only accept serial input, using a laptop which, at
General
http://community.qnx.com/sf/go/post15478
Have a look at www.moxa.com
They have moxattyd utility (for UNIXes, can be easily ported to QNX).
We used Nport 5610, probably they have also newer models now.
http://www.moxa.com/doc/manual/nport/5600/NPort_5600_Manual_v5.pdf
Hope this helps.
PKY
> Hope this helps.
> PKY
We use Moxa nport 5450.
I have tried to configure moxattyd.cf, but not succeed yet.
For example:
ttyp0   10.31.80.80          950
ttyp1   10.31.80.80          951
ttyp2   10.31.80.80          952
ttyp3   10.31.80.80          953
What ever i have to put to the moxattyd.cf file ?
Should i start some (tty/ptyp/serial/...) driver before starting the moxattyd ?
In windows XP and it's drivers everything works fine with the Moxa, but not in QNX.
Esa
> > Hope this helps.
> > PKY
> For example:
>  QNX.
> Esa
It seems to work with settings:
ttypa   10.31.80.80          950
ttypb   10.31.80.80          951
ttypc   10.31.80.80          952
ttypd   10.31.80.80          953
ttyp0 - ttyp3 were in use in some another program.
Esa
