Build Error for bsp-xilinx-zynq7000-zc702_br-660_be-660 using SDP7.0.0
12/19/2017 4:23 AM
post118286
Hi
I installed SDP7.0, and downloaded the Xilinx ZC702 BSP from Foundry27. Imported it into SDP7.0, encountered some build
errors while building (see attached file).
The first build error I encountered is as follows:
C:/qnx700/host/win64/x86_64/usr/bin/qcc -Vgcc_ntoarmv7 -c -Os -Wc,-Wall -DNDEBUG -I. -ID:/home/kianjoo/documents/QNX/
bsp-xilinx-zynq7000-zc702_br-660_be-660/src/lib/gpio/arm/a.le.v7 -ID:/home/kianjoo/documents/QNX/bsp-xilinx-zynq7000-
zc702_br-660_be-660/src/lib/gpio/arm -ID:/home/kianjoo/documents/QNX/bsp-xilinx-zynq7000-zc702_br-660_be-660/src/lib/
gpio -ID:/home/kianjoo/documents/QNX/bsp-xilinx-zynq7000-zc702_br-660_be-660/src/lib/gpio/public -ID:/home/kianjoo/
documents/QNX/bsp-xilinx-zynq7000-zc702_br-660_be-660/src/lib/gpio/../../../install/usr/include -IC:/qnx700/target/qnx7/
usr/include -EL -DVARIANT_a -DVARIANT_le -DVARIANT_v7 -DBUILDENV_qss D:/home/kianjoo/documents/QNX/bsp-
xilinx-zynq7000-zc702_br-660_be-660/src/lib/gpio/main.c
In file included from d:\home\kianjoo\documents\qnx\bsp-xilinx-zynq7000-zc702_br-660_be-660\install\usr\include\sys\
platform.h:380:0,
from C:/qnx700/target/qnx7/usr/include/errno.h:23,
from D:/home/kianjoo/documents/QNX/bsp-xilinx-zynq7000-zc702_br-660_be-660/src/lib/gpio/main.c:23:
C:/qnx700/target/qnx7/usr/include/sys/target_nto.h:179:2: error: unknown type name '_Uintptr32t'
_Uintptr32t _iov_base; \
C:/qnx700/target/qnx7/usr/include/sys/target_nto.h:184:2: error: unknown type name '_Uintptr64t'
_Uintptr64t _iov_base; \
Is there a problem with Uintptr32/64t type? I do see them in the stdint.h. Not sure what __EXT_QNX means.
