Forum Topic - How to configure QNX6.6 to display the application on two monitors?:
In QNX6.6 need to adjust the output of the image to two monitors.
For that, I changed the file / myr./lib/graphics/intel-drm/graphics.conf:
begin khronos
  begin egl display 1
    egl-dlls = libEGL-mesa.so
    glesv1-dlls = libglapi-mesa.so libGLESv1_CM-mesa.so
    glesv2-dlls = libglapi-mesa.so libGLESv2-mesa.so
  end egl display
  begin wfd device 1
    wfd-dlls = libwfdcfg-sample.so libWFDintel-drm.so
    pipeline1-display = 2
    pipeline2-display = 3
  end wfd device
end khronos
begin winmgr
  begin globals
    input = keyboard mouse
    keymap = /usr/share/keyboard/ru_RU_102a
	blit-config = gles2blt
  end globals
  begin display 2
  	cbabc = ui
  	video-mode = 1600 x 1200 @ 60
  	cursor = on
  	stack-size = 4096
  end display
  begin display 3
	cbabc = ui
    cursor = on
    stack-size = 40960
  end display
  begin class framebuffer
  	display = 2
  	pipeline = 1
  	format = rgba8888
  	usage = gles2blt
  end class
    display = 3
    pipeline = 2
  	format = rgba8888
    usage = gles2blt
  end class
  begin mtouch
    driver = devi
    display = 2
  end mtouch
  begin mtouch
  	driver = devi
  	display = 3
  end mtouch
end winmgr
But output of the image still goes to the first monitor (display = 2).
What am I doing wrong?
Re: How to configure QNX6.6 to display the application on two monitors?
Please post the output of drm-probe-displays utility, it will show proper display mapping on your system.
Also please clarify how you output image on display 3 for test purposes? Is it gles1-gears -display=3 command or similar
 to that?
I used the drm-probe-diplays utility for checked the display numbers.
I tried to launch a standard application /usr/bin/gles1-gears, but it is only displayed on the 2nd display.
If I specified when starting application the display number, it will be displayed on that display.
Or so:
/usr/bin/gles1-gears -display=2
, оr so:
/usr/bin/gles1-gears -display=3
I can output different applications on different displays:
/usr/bin/gles1-gears -display=2 & /usr/bin/gles1-gears -display=3
But one application can not be displayed on different displays:
Probably, I need to somehow configure file /usr/lib/graphics/intel-drm/graphics.conf.
