Forum Topic - QNX 6.6 configuring two network interfaces:
I am trying to configure two network interfaces on a 6.6 system.  Both are identical Intel devices.  Ideally I would
like to use DHCP on the first interface and a Static IP on the second but I can get away Static IPs on both if need be.
If someone could post a 'bare minimum' network_start script as a starting point it would be most helpful.
I've got as far as getting both interfaces working but if I use the following:
ifconfig wm1 192.168.1.20
it seems to ignore the static IP and grab one from dhcp instead.
Thanks in advance
Alan
Re: QNX 6.6 configuring two network interfaces
First of all, you must make sure that each interface is on a separate
network. If you want the dhcp.client on the first interface then run
dhcp.client -iwm0
You can then ³ifconfig wm1 192.168.1.20²
Second, if you want to run dhcp.client on both interfaces, you can use the
³-iwmn² on each interface, where ¹n¹ in the interface number.
>are identical Intel devices.  Ideally I would like to use DHCP on the
>following:
>Thanks in advance
>Alan
>General
>http://community.qnx.com/sf/go/post117833
>general-community-unsubscribe@community.qnx.com
