04/17/2017 3:53 AM
post117649
> Hi All,
> We are working on Application using Power Mode provided by QNX Power
> Management Framework on ARM CortexA7 based Board and for one of our
> application we need to put the processor into sleep, standby etc., modes
> supported by QNX. So, here looking at QNX referral document we found that
> sysmgr_cpumode(int mode) does the job for us. But, wanted to know more on this
> function i.e., specifically int mode, what are these mode values to be passed
> while calling the API. Are these mode values are defined in QNX Library. If
> so, where? If not how can we handle CPU Modes using this function.
> On reading more about this API, understood that QNX Power Callout will be
> called by QNX Kernel when this API is called from User Space. Will QNX kernel
> calls Power Callout whenever API is called irrespective of the mode value or
> it depends on any specific mode values. Like,
> MODE Value = GOTOSTANDBY -- Calls Power Callout which changes CPU Mode to
> Standby
> MODE Value = GOTOIDLE -- Calls Power Callout which changes CPU Mode to IDLE
> and so on.
> Can anyone help me in understanding the QNX Power Mode API’s.
> FYI, We do not have Power Management Unit on our hardware.
> Best Regards,
> Dinakar Babu R
Missed to Mention -- We are using QNX 6.6 SDP.
