Forum Topic - QNX not booting in board OMAP3730: (3 Items)
I have a project with BeagleBoard-xm OMAP (DM3730) with 256MB without NAND FLASH works ok, but we migrated for a Gumstix
 Icestorm also using OMAP3 (DM3730) but with 512M Memory RAM and 1G NAND FLASH.
The problem that the image QNX does not start and looks like this:
## Starting application at 0x80200000 ...
NOTE: To recognize the 512 MB of RAM had to use the U-boot 2015.07, but even with the former does not.
Should I change my hardware / startup related to memory?
Attachment: Text qnx.output 560 bytes
Re: QNX not booting in board OMAP3730
They may be the same CPU, but there are many differences between the boards. Even the startup code may need to change.
You likely have a lot of work to do to get this board up and running.
I recommend starting from where? In case of difference in memory RAM where I focus / study?
Thanks for the answer.
