QNX 6.5.0 with SP1 devg-intelhd.so driver
02/09/2016 2:26 PM
post115708
The release note to the latest experimental driver date 2014-05-19 says that intel did=0xa16 is supported. When i run
egl-gears application to test the driver a following error is recorded in the system log:
Feb 09 13:18:32 6 8 0 VGA primary : bus 0x0 dev/func 0x10
Feb 09 13:18:32 6 8 0 Found 1 PCI/AGP display devices
Feb 09 13:18:32 6 8 0 pci_init: found PCI device 8086:a16
Feb 09 13:18:33 6 8 0 [intelhd] Can't detect Intel PCH type
Feb 09 13:18:33 6 8 0 Primary active: 0 10 7
The egl-gears runs fine with vesabios or vga driver.
The pci -v for this particular chip :
Class = Display (VGA)
Vendor ID = 8086h, Intel Corporation
Device ID = a16h, Unknown Unknown
PCI index = 0h
Class Codes = 030000h
Revision ID = bh
Bus number = 0
Device number = 2
Function num = 0
Status Reg = 90h
Command Reg = 7h
Latency Timer = 0h
Cache Line Size= 0h
BAR - 0 [Mem] = f7000000h 64bit length 4194304 enabled
BAR - 2 [Mem] = e8000000h prefetchable 64bit length 134217728 enabled
BAR - 4 [I/O] = f000h length 64 enabled
Subsystem Vendor ID = 8086h
Subsystem ID = a16h
Max Lat = 0ns
Min Gnt = 0ns
PCI Int Pin = INT A
Interrupt line = 11
CPU Interrupt = bh
Capabilities Pointer = 90h
Capability ID = 5h - Message Signaled Interrupts
Capabilities = 0h - 0h
Capability ID = 1h - Power Management
Capabilities = 22h - 0h
Capability ID = 13h - Unknown
Capabilities = 306h - 0h
WHAT I AM MISSING?
