Re: Extending Zynq zc702 BSP driver
05/24/2015 9:32 PM
post113852
Hi Geoff,
I'm not using Zedboard for test, it's a Xilinx zc702 board.
But I believe the BSP package in the linkage I posted previously would also work on Zedboard (Maybe with slight
modifications).
I don't recall I ever met big problems while getting the BSP running. It was a smooth process. But I'm not sure if it
will be the same case with Zedboard.
You will need QNX Momentics and Xilinx SDK and Xilinx Vivado to make the most use of features on your test board.
If you meet any problem, we can discuss together. I'm happy to have some one discuss with in this forum.
Regarding the topic I posted, I have given up the idea extending the BSP for now. Since simply manipulating timer
registers can make it work, I will consider build it into BSP together with other devices in PL.
Randy
